I Homemorphism in quotient topology
elias001
Questions
I have two general questions about the topic of quotient topology.. Suppose I have a set ##X## and I defined an equivalence relation ##\sim## on ##X## and I want to know what quotient toplogical sapce is hoemeorphic to. I have included a list of definitions, lemmas, propositions and theorems from two different textbooks in the Background section below. Specifically the two question I have is one,
##Question 1## If given a set ##X## and an equivalence relation ##\sim## on ##X##, sometimes an exercise in a topology text would ask the reader to identify what the quotient space is or what the equivalence relation defined on set ##X## is homeomorphic to. How does one usually go about such exercise. I assumed by visualizing or the process of identifying, it requires one to provide a proof.
##Question 2## Suppose in ##Question 1##, I know what the quotient topological space is but the construction can be only describe using picture/verbal descriptive type style proofs. To be specific, take the mobius strip, everyone has seen how they have seen a rectangular strip ##R## with direction arrows running along each of the four edges, and we have the equivalence relations ##(x,0)\sim (1-x,1)##, one is suppose to identify the opposite edges of the rectangular strip ##R## by doing a ##180## degree twist. Depending on the sophiscation of the textbook, a reader might be presented an parametric representation of the mobius strip, basically what one would see in a differential topology text,, in terms of charts. This last two points, are important because depending on the type of quotient topological space, a parametric representation of it might not always be readily know. So how does one go about showing homeomorphism with just a given equivalence relation.
Background
The following are from Topology by Murray Eisenberg and Elements of Algebraic Topology by: Anat Shastri
[Topology by Murray Eisenberg]
Lemma 1 Let ##\sim## be an equivalence relation on a topological space ##X##, and let ##p:X\to X/\sim## be the quotient map. Then the collection
$$T=\{V\subset X/\sim:p^{-1}(V)\text{ open in }X\}$$
is a topology on the quotient set ##X/\sim.##
Definition 1 The quotient of a topological space ##X## under an equivalence relation##\sim## is the topological space whose underlying set is ##X/\sim## and whose topology is the collection ##T## described above. This topology is called the quotient topology.
Proposition 1: Let ##p:X\to X/sim## be the quotient map induced by an equivalence relation ##\sim## on a topological space ##X.## Then the quotient topology is the greatest topology on ##X/\sim## making ##p## continuous.
Theorem 1: A map
$$g:X/\sim\to Y$$
from a quotient space ##X/\sim## into a topological space ##Y## is continuous if and only if its composite
$$g\circ p:X\to Y$$
with the quotient map ##p:X\to X/\sim## is continuous..
Theorem 2: Let ##p:X\to X/\sim## be the quotient map induced by an equivalence relation ##\sim## on a topological space ##X.## Let ##f:X\to Y## be a continuous map from ##X## into a topological space ##Y## that is constant on each equivalence class under ##\sim,## that is,
$$x\sim t\quad \Rightarrow\quad f(x)=f(y)\quad\quad (x,t,\in X).$$
Then there is a unique continuous map
$$f^{*}:X/\sim\to Y$$
such that
$$f^{*}\circ p=f.$$
Moreover:
##\quad (1)## The map ##f^{*}## is surjective if ##f## is surjective.
##\quad (2)## The map ##f^{*}## is injective if ##f## takes distinct values at representatives of different equivalence classes under ##\sim.##
##\quad (3)## The map ##f^{*}## is open if ##f## is injective. and the open subsets of ##Y## are those subsets ##W## of ##Y## for which ##f^{-1}(W)## is open in ##X.##
Proposition 2: Each continuous open surjection and each continuous closed surjection is a quotient map.
[Elements of Algebraic Topology by: Anat Shastri]
Let ##q:(X,\tau)\to (Y,\tau')## be a surjective map (i.e. continuous function) of topological spaces.
Lemma 2: The following statements are equivalent.
##(i)## ##U\in \tau'## iff ##q^{-1}(U)\in\tau.##
##(ii)## A function ##g:(Y,\tau')\to (Z,\tau'')## is continuous iff ##g\circ q## is continuous.
##(iii)## For a fixed ##\tau,\tau'## is the maximal topology on ##Y## such that ##q## is continuous.
Definition 2: Under the above conditions, we say ##(Y,\tau')## is a quotient space of ##(X,\tau)## and the map ##q## is called a quotient map.
Thank you in advance
It should not be difficult to get from a graphical description to a parametrisation.
For example, for the Mobius strip one can take a line segment with centre on a circle of radius R such that the angle to the horizontal plane goes through a half rotation as the centre moves through a full rotation. That leads to something like
\begin{split}x &= (R + (u-\tfrac12)\cos (\pi v))\cos (2\pi v) \\y &= (R + (u-\tfrac12) \cos (\pi v))\sin (2\pi v) \\z &= R + (u-\tfrac12) \sin (\pi v). \end{split}
for R > 1.
@pasmith Is it always necessary to prove homeomorphism by finding explicit parametrization from graphical descripption, or can one do it by relying solely on the description based on equivalence relations?
A graphical description is not really a rigorous proof, although it might help you to find one.
Ultimately, showing that X/\sim is homeomorphic to Y requires finding a continuous function f: X/\sim \to Y and showing that it has a continuous inverse.
For example, showing that [0,1]/\sim where 0 \sim 1 and otherwise x \sim y \Leftrightarrow x = y is homeomorphic to S^1 can be done via the map [x] \mapsto (\cos (2\pi x), \sin (2\pi x)).
@pasmith what about the case of the klein bottle or roman surface? For the klein bottle, I only find how is parametrize in ##R^3## in two different books about differential forms.
elias001 said:
Questions
Background
Theorem 1: A map
$$g:X/\sim\to Y$$
$$g\circ p:X\to Y$$
such that
$$f^{*}\circ p=f.$$
Moreover:
I don't think this is an easy question in general. Yhere is no magic answer. Every smooth manifold can be described as a quotient of patches of ##\mathbb R^n##. If this problem was mechanical then problems like the Poincare conjecture would be simple.
Now if you just want to embed the quotient space in ##\mathbb R^{2n}## then this is an easier question at least in the smooth category via the Whitney Embedding theorem.
I posted this question on math-stackexchange but apparently I asked something stupid and I was downvoted. I still don't have an answer to my question so I hope someone in here can help me or at least explain me why I am asking something stupid. I started studying Complex Analysis and came upon the following theorem which is a direct consequence of the Cauchy-Goursat theorem: Let ##f:D\to\mathbb{C}## be an anlytic function over a simply connected region ##D##. If ##a## and ##z## are part of...
