Poirot1
- 245
Find a homeomorphism between Q={(x,y,z):$x^2+y^6+z^{10}=1$} and the unit sphere in R^3
Shouldn't that be $f(x,y,z)=(x,y^3,z^5)$? Alternatively, doesn't the above map $f$ go from $S^2$ to $Q$? (Worried)Fernando Revilla said:Have you tried $f:Q\to S^2,\; f(x,y,z)=(x,\sqrt[3]{y},\sqrt[5]{z})$ ?
Not necessarily – you're looking for a homeomorphism, not a diffeomorphism. In other words, the map and its inverse need to be continuous, but not necessarily differentiable.Poirot said:Does f and f^-1 being continuous mean all partial derivatives exist?
Aren't you supposed to know that by this stage? (Giggle)Poirot said:So what is the definition of f being continuous?
Correct – if you show that the map and its inverse are differentiable then that will imply continuity.Poirot said:Actually, being differentiable is a sufficent condition so that will do
Opalg said:Shouldn't that be $f(x,y,z)=(x,y^3,z^5)$? Alternatively, doesn't the above map $f$ go from $S^2$ to $Q$? (Worried)
A homeomorphism is a mathematical concept that describes a continuous and invertible mapping between two topological spaces. In simpler terms, it is a function that can transform one shape into another without any tearing or gluing.
The unit sphere in R^3 is a mathematical object that represents all points in three-dimensional space that are equidistant from the origin. It is often referred to as the surface of a ball with a radius of 1.
This homeomorphism is significant because it establishes a topological equivalence between the set of rational numbers (Q) and the unit sphere in three-dimensional space. This means that these two seemingly different mathematical objects share the same topological properties.
This homeomorphism can be proven by constructing a continuous and invertible function between Q and the unit sphere in R^3. This function should preserve the topological structure of both spaces, such as open sets and connectivity.
This homeomorphism has various applications in mathematics and physics. It can be used in geometric constructions, topological data analysis, and in understanding the properties of rational numbers and the unit sphere in R^3. It also has applications in fields such as computer graphics and computer vision.
