Homework SolutionAngular Acceleration of a Fan
The discussion revolves around calculating the angular acceleration and the number of revolutions of a fan as it slows down from 500 rev/min to 200 rev/min in 4 seconds. The correct angular acceleration was determined to be -1.25 rev/s². There was confusion regarding the calculation of the number of revolutions, initially thought to be 5, but clarified that it requires the initial angular velocity. The correct approach involves using the angular displacement formula, incorporating both the initial velocity and acceleration. Ultimately, the calculations reveal that the total angular displacement is -17.50 revolutions.
valeriex0x
angular acceleration of a fan!
An electric fan is turned off, and its angular velocity decreases uniformly from 500 rev/min to 200 rm rev/min in 4.00 s.
Find the angular acceleration in rev/s and the number of revolutions made by the motor in the 4.00 interval.
I got -1.25 for alpha in rev/sec^2, which is correct.
How come the number of revolutions isn't 5 revolutions?
(alpha) (time)=
(-1.25)(4 sec)=5 rev (-5) rev
Acceleration x time = velocity, not distance!
ohhhhhhhhhhh... ok thanks. hmmm... I'm not sure what formula i should use. i was going to try x=xo+vot+1/2at^2 but i can;t. .....
Why not? (assuming of course that you'd use the angular form of the equation)
i don't have xo right?
we didn't cover this yet...
Assume xo is zero. The count of revolutions (distance) begins, and the clock starts ticking, at the instant the fan is turned off.
okay so :
0+(-1.25 rev/s^2)(4 sec)+ 1/2(-1.25 rev/s^2)(4^2)
x=-5.00+ -12.50
x=-17.50
how do i make this angular?
valeriex0x said:
okay so :
x=-5.00+ -12.50
x=-17.50
You're using angular values, so it's angular.
But you've got a problem. You're using an acceleration where the initial angular velocity is required.
