Homogenization of a plate to an equivalent rod .
To convert a steel plate into an equivalent rod with the same stiffness, first calculate the plate's deflection under load and derive its stiffness. Set the plate stiffness equal to the rod stiffness, defined by the formula kr = E*A/L, where E is the modulus of elasticity, A is the cross-sectional area, and L is the length of the rod. You can choose any two of these parameters to solve for the third. The plate and rod will not generally have the same mass unless an additional constraint is applied to match their densities and volumes. This approach allows for a systematic way to achieve equivalent stiffness while considering mass differences.
perfectz
Homogenization of a plate to an equivalent rod...
Folks, I have a doubt... Sorry if it is a really stupid one...:rolleyes:
Imagine you have a steel plate say 200mm by 200mm in dimension, with a stiffness of say some "k" N/mm...
Is there any formula to convert that plate into an equivalent steel rod with the same stiffness of "k" N/mm?...
Waiting for your answers.....:bugeye:
First, compute the plate deflection under the applied load. Then divide the applied load by the plate deflection to obtain the plate stiffness, kp. Now set kp equal to the rod stiffness, kr, where kr = E*A/L, E = rod modulus of elasticity, A = rod cross-sectional area, and L = rod length. For the three parameters E, A, and L, arbitrarily set any two of these parameters, and solve for the third.
Ok thanks buddy... Thank you very much...
will the plate and rod have the same mass after homogenization? It won't right?
The plate and rod generally will not have the same mass. You could design them to concurrently have the same mass by introducing an additional constraint equation, rhor*Vr = mp, where rhor = rod density, Vr = rod volume, and mp = plate mass.
I have Mass A being pulled vertically. I have Mass B on an incline that is pulling Mass A. There is a 2:1 pulley between them. The math I'm using is: FA = MA / 2 = ? t-force MB * SIN(of the incline degree) = ? If MB is greater then FA, it pulls FA up as MB moves down the incline. BUT... If I reverse the 2:1 pulley. Then the math changes to... FA = MA * 2 = ? t-force MB * SIN(of the incline degree) = ? If FA is greater then MB, it pulls MB up the incline as FA moves down. It's confusing...
