Homopolar Generator: 0.1V Output, No Current
A homopolar generator using an aluminum disk is producing an output voltage of 0.1V but is not generating any current, despite checks for resistance, contact, and field symmetry. The resistance of the disk is measured at 1 ohm, which is deemed too high for the low voltage output to produce any significant current. Suggestions for generating high current include using a small toroid mains transformer with thick copper wire, although this method produces AC rather than DC. The user also attempted to supply 5 amps at 12V to test rotation, but the disk did not rotate. Overall, the discussion highlights challenges in achieving the expected current output from the homopolar generator setup.
kannuhny24
I've made a homopolar generator using Al disk, its giving me a output voltage of around 0.1V but shockingly der is no current ! a checked the resistance of the disk its very low as required, i checked for every other problem like : improper contact , smoothness of the disk , symmetry of the field , speed , proximity of the field , insulation of the rotor shaft with the disk , using a thick disk ( around 5 mm ) etc...but there is no current ! can anybody tell me what might have gone wrong...?? homopolar generator is supposed to generate high current at low voltages i want to verify it, can anybody suggest any other way of producing very high current it doesn't matted at what voltage ii just want high current.
Science news on Phys.org
What are you using for a load? How are you measuring the current?
The problem is you almost certainly got too much resistance in your circuit. Say you want 10 Amp then since your voltage is 0.1V, R got to be lower than 0.01 Ω which is not easy to do.
The way I generated a high current in the past is by using a small toroid mains transformer. Thread one or two loops of thick cupper wire through the hole and solder the ends of the wire together. Make sure some of this wire runs outside the transformer. I was able to generate 300 Amps and more. But of course that is ac and not dc. But make sure the primairy coil is not overheating and be careful with the mains voltage.
@pantaz : i simply used the multimeter to check the V and I.
@ per oni : the resistance of my disk is 1 ohm...should hav atleast shown 0.1 o some amps but it dint show any...should i go fr Cu disk ?... I even supplied 5amp @12V between the periphery and the centre to see if it atleast rotates but it dint rotate too !
Thanks fr replying guys.
Thread 'Simple math model for a Particle Image Velocimetry system'
Hello togehter, I am new to this forum and hope this post followed all the guidelines here (I tried to summarized my issue as clean as possible, two pictures are attached). I would appreciate every help: I am doing research on a Particle Image Velocimetry (PIV) system. For this I want to set a simple math model for the system. I hope you can help me out. Regarding this I have 2 main Questions. 1. I am trying to find a math model which is describing what is happening in a simple Particle...
Thread 'How to model converging illumination through object plane (in ZEMAX)'
Hello community, I'm designing a projection lens system for a 35mm film projector in Zemax OpticStudio and struggling with the correct sequential mode setup for the illumination geometry. The light source is a Xenon short-arc lamp reflected by an ellipsoid mirror, which creates a converging cone with a 40.6 degree full angle that passes through the film gate. The film gate is my object plane, but the light doesn't diverge from it like a typical Lambertian source. Instead, the converging...
