How best to install a pressure sensor inside a pipe?
To measure suction pressure in a 25 mm diameter pipe without disturbing flow, a pressure sensor must be carefully chosen to avoid significant flow disruption. Installing a sensor inside the pipe can alter the pressure profile, especially in smaller diameters, making it challenging to achieve the desired precision of milliPascal. A side-mounted pressure port may not be effective for accurate readings. Achieving a resolution of 1 mPa in a system with a baseline pressure of 100 kPa requires advanced sensor technology. Reevaluating the installation method and sensor specifications is essential for accurate pressure measurement.
as919461
Dear memebers,
I have a test setup with a pipe (25 mm dia) having certain holes with a suction fan at the end of pipe. I need to check the suction pressure generated in the holes. What type of sensors can i use to install inside the pipe (above the hole in the mainstream) which doesn't disturb the flow profile and have a precision of mili Pa. Thank you. )
Inside the pipe? A pressure port on the side won’t work?
You’re already looking at putting a hole in the pipe wall for wires, right? And what exactly are you expecting to find different between the center of the pipe and the wall of it, especially at that diameter?
As an additional complication for putting the sensor in the flow, it will disrupt said flow and cause pressure changes as the fluid flows past it. On a much larger pipe, say, 150mm, it would probably be a minimum issue, but at your scale… it’ll be noticeable.
Welcome to PF.
as919461 said:
I need to check the suction pressure generated in the holes. What type of sensors can i use to install inside the pipe ... and have a precision of mili Pa.
If the pressure outside the pipe is 1 atm = 100 kPa, and you want 1 mPa resolution, that is 100 kPa / 1 mPa, which is 8 orders of magnitude. That will take some doing.
You need to reconsider what you are doing and why.
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
