How Big of a Motor Do I Need to Move a 12t Cart on Rails at 5m/min?
  • Thread starter Thread starter Inenzo
    Cart Static
To calculate the motor size needed to move a 12-ton cart on rails at 5 meters per minute, key factors include the gearbox ratio, wheel size, and incline of the surface. The cart has a flat surface and uses wheels measuring 230mm. The total mass is confirmed to be 12 tons, which is the maximum load. Determining the gearbox ratio is essential for calculating the maximum torque required from the motor. Accurate specifications will enable a more precise motor size calculation.
Inenzo
Need to calculate motor size to drive skip dolley system. have the following:
Frame on 6 wheels. Gearbox/motor driving middle pair of wheels.
Total mass 12t
Need to move trolley @ 5m/min
Any thoughts where to begin?
Well I'll take a stab at it,
whats the ratio on your gearbox?
size of wheels?
is the trolley for use on a flat surface or how steep are the biggest inclines?
What sort of load will it be carrying? is 12t the maximum load or just the weight empty?
Once you know those, I think we can figure out the maximum torque needed from your motor.
Wheels = 230mm
flat surface
max load = 12t
ratio on gearbox=? Don't know the ration since we need to source it still...
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
