How can a cube be inscribed in a right circular cone?
  • MHB
  • Thread starter Ackbach
  • Tags
    2016
In summary, inscribing a cube in a right circular cone involves drawing the base of the cone, determining its center point, and drawing lines from the center point to the edge of the base to create the sides of the cube. The dimensions of the cube and the cone are directly related, with each side of the cube being equal to the diameter of the base of the cone and the height of the cube being equal to the height of the cone. A cube can be inscribed in any size right circular cone as long as the dimensions are proportional. The benefits of inscribing a cube in a right circular cone include stability, efficient use of space, and visual symmetry. However, there are limitations such as the need for proportional dimensions and a suitable
Ackbach
MHB
4,155
93
Here is this week's POTW:
A right circular cone has base of radius 1 and height 3. A cube is inscribed in the cone so that one face of the cube is contained in the base of the cone. What is the side-length of the cube?
Remember to read the http://www.mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to http://www.mathhelpboards.com/forms.php?do=form&fid=2!
Re: Problem Of The Week # 237 - Oct 14, 2016
This was Problem A-1 in the 1998 William Lowell Putnam Mathematical Competition.
Congratulations to kiwi for his correct solution, which follows:
The top face of the square is located at an elevation equal to the side length, I call this y.
The top face is inscribed in a circular section of the cone with radius $r = 1-y/3.$
The top face is a square with side length $y = r\sqrt{2}.$
Combining these two equations:
\(r=\frac y { \sqrt 2} = 1 - \frac y3\)
so
\(\frac{3y}{ \sqrt{2}} = 3 - y\)
\(y=\frac{3}{\frac{3}{\sqrt{2}}+1}=\frac{3 \sqrt{2}}{3+\sqrt{2}} \approx 0.96\)
