How can a mirror reflect 99,999% of incident light?
In summary, the conversation discusses the efficiency of mirrors in reflecting incident light, particularly in the context of laser mirrors. It is mentioned that regular mirrors do not reflect all wavelengths at 99.999% efficiency and that laser mirrors are specifically selected to have high reflectivity in a narrow range of wavelengths. The conversation also touches on the properties of a photon with the correct wavelength for maximum reflection and its detection in a narrow angle cone. However, the conversation becomes vague and insulting, resulting in the thread being closed.
intervoxel
195
How can a mirror reflect 99,999% of incident light? Or in other words what makes a photon exiting a laser cavity so directional?
In fact, I never found a really convincing answer. Thank you.
Laser mirrors are usually dielectric multilayer mirrors and commonly reflect up to 99.99% in target line. Also, even conventional metal mirrors have higher reflection coefficients in middle infrared range. For example, gold mirrors are 99.0% reflective at 10um wavelength.
Your question is vague. No mirror can reflect ALL wavelengths at 99.999% efficiency. The regular mirror that you and I are used to may appear to be a good reflector of visible light, but put that in a UV-VIS spectrometer, and you'd be surprised at reflectivity spectrum, even in the visible range. And forget about UV, because such a mirror is hopeless.
Mirrors in laser cavity has been specifically selected so that it has the highest reflectivity in a very narrow range of wavelengths. So it has been finely tuned to work under a very narrow parameter.
Zz.
Likes intervoxel
Zz.
Nice answer, ZapperZ. Let's suppose now one single photon with the correct wave length to get maximum reflection. What happens to the properties of the photon to have higher probability of detection in a very closed angle cone in the direction of reflection?
Why should I do this work for you especially when this is still quite vague?
Zz.
Likes Cryo
The OP has received a warning for insulting another member. Thread closed.
Related to How can a mirror reflect 99,999% of incident light?
1. How is it possible for a mirror to reflect 99.999% of incident light?
The reflective surface of a mirror is typically made of a highly polished material, such as glass or metal. This smooth surface allows for the majority of light to be reflected back in a predictable manner, resulting in a high percentage of reflected light.
2. What factors contribute to a mirror's ability to reflect light?
The material used for the reflective surface, the smoothness and flatness of the surface, and the angle at which the light hits the mirror all play a role in its reflective capabilities. Additionally, the quality of the coating on the mirror can also impact its reflectivity.
3. Is it possible for a mirror to reflect 100% of incident light?
No, it is not possible for a mirror to reflect 100% of incident light. Even the most perfectly polished and coated mirrors will still absorb a small amount of light, resulting in less than 100% reflectivity.
4. Can the reflectivity of a mirror change over time?
Yes, the reflectivity of a mirror can change over time due to factors such as dust, dirt, and scratches on the surface. It is important to regularly clean and maintain mirrors to ensure optimal reflectivity.
5. Are there any limitations to a mirror's ability to reflect light?
Yes, there are limitations to a mirror's ability to reflect light. The angle at which the light hits the mirror, the quality of the coating, and the material used for the reflective surface can all impact the maximum percentage of light that can be reflected.
  • Classical Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
