MHB How Can $\frac{\sec\theta}{\tan\theta}$ Be Simplified to $\csc(\theta)$?
  • Thread starter Thread starter tmt1
    Simplifying Trig
The expression $\frac{\sec\theta}{\tan\theta}$ can be simplified to $\csc(\theta)$ by converting secant and tangent into sine and cosine functions. This involves rewriting $\sec(\theta)$ as $\frac{1}{\cos(\theta)}$ and $\tan(\theta)$ as $\frac{\sin(\theta)}{\cos(\theta)}$. By performing the division, the equation simplifies to $\frac{1}{\sin(\theta)}$, which is equal to $\csc(\theta)$. It's important to note that this simplification is valid under the conditions that $\sin(\theta) \neq 0$ and $\cos(\theta) \neq 0$. Thus, $\frac{\sec\theta}{\tan\theta} = \csc(\theta)$ when these restrictions are met.
tmt1
I have $\frac{sec\theta}{tan\theta}$. How can I simplify it to get $\csc\left({\theta}\right)$ ?
Mathematics news on Phys.org
I prefer to change everything to sines and cosines.
[math]\frac{sec( \theta )}{tan( \theta )} = \frac{ \frac{1}{cos( \theta )}}{ \frac{sin( \theta )}{cos( \theta )}}[/math]
[math]= \frac{ \frac{1}{cos( \theta )}}{ \frac{sin( \theta )}{cos( \theta )}} \cdot \frac{ cos( \theta )}{cos( \theta )}[/math]
[math]= \frac{1}{sin( \theta )} = csc( \theta )[/math]
With, of course, the restrictions that [math]sin( \theta ) \neq 0[/math] and [math]cos( \theta ) \neq 0[/math]
-Dan
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
