How Can I Calculate the Final Velocity of a Wagon on a Hill Using Physics?
  • Thread starter Thread starter Izekid
    Physics Velocity
To calculate the final velocity of a wagon rolling down a hill, energy conservation principles can be applied, using potential and kinetic energy equations. The initial potential energy (mgh) and initial kinetic energy (1/2 mv1^2) equal the final potential energy (0, at the bottom) and final kinetic energy (1/2 mv2^2). The equations yield consistent results, confirming that energy is conserved during the motion. The calculations can also be approached using the equations of motion, where v^2 = v0^2 + 2ax, with height as the distance. Both methods lead to the same final velocity, illustrating the relationship between height, initial velocity, and gravitational acceleration.
Izekid
There's a wagon standing on a hill
The Height :0,81m
When v1 = 0m/s then v2 = 4m/s when the wagon has rolled down the slope.
What is the velocity when the startvelocity is 2m/s ...
How do I do this...
I've tried many things but I don't know the mass so how should I do?
Please help
try using potential and Kinetic energy equations
Is this right?
Is this right then... I take 2m/s which is v1 and put in in kinetical energy equation and take out v^2= Sqrt 2*g*h = 4,45 which is the right answer but I don't seem right it must be harder than that
Energy is conserved;
Eintial = Efinal
Pei + Kei = Pef + Kef
mgh + 1/2mvi^2 = 1/2mvf^2
or from equations of motion:
v^2 = v0^2 + 2*a*x where x is h
both result in the same answer.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
