How Can I Calculate the Number of Photons in a Laser Cavity?
To calculate the number of photons in a laser cavity formed by two mirrors, one with ultra-high reflectivity and the other at 99.5%, the power of the laser is 1mW with a wavelength of 600nm. The initial calculation yields approximately 3.01x10^15 photons at full power. Adjusting for the output power based on reflectivity results in a photon output of about 2.86x10^15 photons per second. The time spent in the cavity is estimated at 1 nanosecond, leading to a calculation of photons escaping the cavity as 3.01x10^24. The discussion concludes with uncertainty about the correctness of these calculations and the relevance of the time element used.
Vegeta2019
The laser cavity is formed by two mirrors separated by 15 cm. One of the mirrors has an ultra-high reflectivity and the output mirror has the much lower reflectivity of 99.5 %. How many photons are there in the cavity?[/B]
The power of the laser is 1mW and the wavelength is 600nm
E= hc/λ and N=P/E Hence N = Pλ/hc
Power out = Power in x (1 - reflectivity) ... Not sure about this formula
I have different views to what is happening as I think the question is vague. So I only have worked out certain elements.
At full power N = Pλ/hc ... N=3.01x1015
We could work out the time inside the cavity t = 30x10-2 /3x108 which gives 1 nano second... Not sure if this is relevant to the question.
Using the formula Power out = Power in x (1 - reflectivity) gives a power of 1x10-3 x(1 -0.05)
=9.5x10-4
Using this new power N = Pλ/hc... N= 2.86x1015 photons/s
Would I then do 3.01x1015 - 2.86x1015 = 1.6x1014 ??
Not sure if this is correct. Is the time element I tried supposed to be used?
I would approach the problem this way: start by calculating the number of photons escaping the cavity per unit time, then figure out how many photons per unit time need to be hitting the semi-reflecting mirror for the calculated output, then figure out how many photons must be inside the cavity to get this hit rate on the mirror.
So If I work our the photons escaping the cavity per uni time this would look like
Photons escaping = 3.01x1015 / 1x10-9 =3.01x1024 since the time the spend in the cavity is 1 nano second??
From my attempt the number of photons needed to hit the semi reflecting mirror is N= 2.86x10^15 photons/s due to the 0.5% loss?
So it would be 3.01x1024 - 2.86x1015 = 3x1024
Still not sure if I am doing this correct.
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
