MHB How can I create a strong password to protect my online accounts?
  • Thread starter Thread starter Asawira Emaan
To create a strong password for online accounts, it is essential to use a combination of uppercase and lowercase letters, numbers, and special characters. Passwords should be at least 12 characters long to enhance security. Avoid using easily guessable information such as birthdays or common words. Regularly updating passwords and using unique passwords for different accounts can further protect against breaches. Implementing a password manager can help in generating and storing complex passwords securely.
Asawira Emaan
Asalamoalikum,
Kindly can someone solve these with explanation?
1. In how many ways can four French books, two English books and three German books be arranged on a shelf so that all books in same language are together.
2. How many different arrangements can be formed of the word "equation" if all the vowels are to be kept together?
3. A combination lock has five wheels, each labeled with the ten digits from 0 to 9. How many five number opening combinations are possible,
(i) assuming no digit is repeated.
(ii)assuming digits can be repeated.
Thank you.
Mathematics news on Phys.org
Asawira Emaan said:
Asalamoalikum,
You won't learn anything by people doing your homework for you! Here are some hints:
First, treat the books of each language, which must be kept together, as one object. In how many ways can you arrange 3 objects? Now, in how many ways can you arrange just the 4 French books? The two English books? The three German books? By the "fundamental counting principle", multiply those.
Treat the vowels, e, u a, i, and o, that are to be kept together, as a single letter. there are also 3 consonants so, treating the vowels as a single letter, there are 4 objects. In how many ways can you arrange 4 objects. In how many ways can you arrange the 5 vowels?
There are 10 choices for the first digit, then 9 for the second, etc.
Then there are 10 choices for every digit.
Thank you.
Country Boy said:
You won't learn anything by people doing your homework for you! Here are some hints:First, treat the books of each language, which must be kept together, as one object. In how many ways can you arrange 3 objects? Now, in how many ways can you arrange just the 4 French books? The two English books? The three German books? By the "fundamental counting principle", multiply those. Treat the vowels, e, u a, i, and o, that are to be kept together, as a single letter. there are also 3 consonants so, treating the vowels as a single letter, there are 4 objects. In how many ways can you arrange 4 objects. In how many ways can you arrange the 5 vowels?There are 10 choices for the first digit, then 9 for the second, etc.Then there are 10 choices for every digit.
Thanks by the time I got this answer I had already done the homework.
Good! That's the way it should be!
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
