How can I derive the period of oscillation for a relaxation oscillator?
  • Thread starter Thread starter limofunder
    Oscillator
To derive the period of oscillation for a relaxation oscillator, the relationship involves the resistances R1, R2, the capacitance C, and the supply voltages VCC and VEE. The discussion references fundamental equations from electromagnetism, including V=IR and C=Q/V, and attempts to establish a differential equation for current I. The user deduces that the current can be expressed as I = I0Exp[-t/RC], indicating an exponential decay. The challenge lies in relating the output voltage V_out to the current using the voltage divider formula, while also addressing formatting issues with LaTeX code. Overall, the focus is on deriving the correct mathematical relationships for the oscillator's behavior.
limofunder
I am having a bit of trouble with a homework problem on relaxation oscillators, the schematic is shown below:
https://webspace.utexas.edu/sz233/Relaxation%20Oscillator.png
The original problem states:
derive a relationship for the period of oscillation for a relaxation oscillator in terms of R1, R2, RC, VCC
and VEE.
So I know from E&M that
V=IR, and C=Q/V.
also, I know that dq/dt = I
from this, I deduce, possibly erroneously, that
V_- = IR +\frac{1}{C} \int I(t)dt
so
0 = R \frac{dI}{dt} + \frac{1}{C} * I(t)
then
\frac{dI}{I} = - \frac{1}{RC} dt
it follows that
I = I0Exp[-t/RC]
given that current doesn't change at the + or - poles on the amplifier, then this should be the same current that goes through V+ thus using the voltage divider formula,
V_out = V_+ * \frac{R_2}{R_1 + R_2}
Now, how do I relate the Vout here with the current from above?
Is there a reason for which the latex code doesn't appear? I pulled the notation direct from the sigma reference in the tool box menu
thanks a bunch guys
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
