How can I find the velocity and acceleration of a particle in 2-dimensions?
  • Thread starter Thread starter Filenes
To find the velocity and acceleration of a particle in two dimensions, the position vector is given as r = (7.40 i - 6.60t² j) m. The velocity can be derived by differentiating the position vector with respect to time, resulting in v = (0 i - 13.20t j) m/s. The acceleration is found by differentiating the velocity, yielding a = (0 i - 13.20 j) m/s², indicating constant acceleration in the j-direction. For part (b), at t = 2.00 s, the position is r = (7.40 i - 26.40 j) m and the velocity is v = (0 i - 26.40 j) m/s. Understanding these calculations involves recognizing the definitions of instantaneous velocity and acceleration as derivatives of position with respect to time.
Filenes
The vector position of a particle varies in time according to the expression r = (7.40 i - 6.60t2 j) m.
(a) Find expressions for the velocity and acceleration as functions of time. (Use t, i, and j as necessary.)
v =
a =
(b) Determine the particle's position and velocity at t = 2.00 s.
r =
v =
kinematic of 2-dimen
r= v/t
I found (b) r.. but i have no clue how to start part (A), i thought since R = V/t then
r =(7.40i - 6.60t^2)/ t but that was wrong.. so I'm thinking that r should be change into something. Any help would be great
What is the definition of Velocity and Acceleration with respect to distance and time?
r/t is average velocity. your trying to find the instaneous rate of change. which means its time to put that calc 1 to use!
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
