How can I find time, given the frequency?
  • Thread starter Thread starter TaintedLove
    Frequency Time
Frequency is defined as the inverse of time, expressed as frequency = 1/t, applicable in all cases. In the context of a momentum lab example with a frequency of 1/50, this indicates a period of 50 seconds. Frequency is typically measured in Hertz, which is equivalent to cycles per second, although units for cycles are often omitted. The variable 't' usually represents the period (T), which measures the time it takes for a wave to complete one cycle. Understanding these concepts is crucial for accurately interpreting frequency and time relationships.
TaintedLove
I know frequency = 1/t, but is that in every case? In our momentum lab, we were given that the frequency is 1/50... does that mean the time is 50s?
Frequency is usually given in Hertz: Hertz = 1/s
But using any units, yes it is 1/t.
You can think of it as "cycles/second" if you want (or any other time unit), but we just don't write units for cycles.
So yes it is for every case. the t is usually T which stands for the period, you just need to decide in every case what T is measuring.
Usually how long it takes for a wave to repeat itself.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
