How can I graph a heat equation with multiple variables in Maple?
Ultramilk
Graph T(x,t) = T1e^(lambda*x)sin(wt-lambda*x) in Maple
lambda = -.2
T1 = 10
omega = constant
Maybe heat equation
ut(x,t) = uxx(x,t)
I'm really unsure on how to graph a multiple variable function/equation in Maple. I gave it a couple of tries using plot3d, but I really don't have a clear understanding of how exactly the functions work (I only plot 2d stuff before this).
My only close attempt was when I typed in:
plot3d(T1e^(lambda*x)sin(wt-lambda*x), x=0..10, t=0..10)
where I had define lambda := -.2 and T1 := 10;
It didn't give me any errors, but it gave me an empty plot.
I also looked up procedures in graphing heat equation, but it didn't give me a plot I wanted. Rather I wanted a plot in 3d, while it gave me a plot in 2d as the end result.
I guess my biggest problem right now is how to get Maple to treat omega (w) as a constant. Should I leave it out while trying to plot it? Because when I do I get a curved 2d line on the graph.
I'm unsure if graphing if covered in this forum, but it would be really helpful if a person could direct me in the right direction, maybe drop some advice as to which plot to use (like PDEplot or if plot3d is fine?)
Thanks a lot for the help guys.
So I kept trying it, and looking up guides to graph said equation in the end I got:
T(x,t) := 10 exp(-.2 *x)*sin(omega*t+.2*x);
plot3d(T(x, t), x = -10 .. 10, t = 0 .. 10, axes = framed, orientation = [-20, 20])
I don't think I need too many lines of code to graph it, but I keep getting a flat graph. I mean I get a 2d plot on the xt plane while I want a 3d plot. I'm not 100% what I'm doing wrong, does anybody have a clue?
Thank you.
Thank you.
I assume you have assigned a value to ω (you can't leave it undefined in a plot). I think if you remove the (x,t) like this:
T := 10 exp(-.2 *x)*sin(omega*t+.2*x);
plot3d(T, x = -10 .. 10, t = 0 .. 10, axes = framed, orientation = [-20, 20]);
it will work.
Oh wow that worked :O
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
