How Can I Highlight Text Background When Hovering Over Radio Buttons?
  • Thread starter Thread starter jjiimmyy101
    Radio
The discussion revolves around a coding issue where the user wants to highlight the background of text labels associated with radio buttons when the mouse hovers over either the radio button or the label itself. The initial code only highlights the background of the text when the mouse is over the text or the radio button separately. A solution is provided by suggesting the addition of unique IDs to the labels, allowing direct manipulation of the label's background style within the radio button's mouseover events. This approach successfully enables the desired effect of highlighting the text background regardless of whether the mouse is over the radio button or the label. The user expresses gratitude for the simple solution.
jjiimmyy101
This is probably an easy solution, but I can't figure it out for the life of me. I have a bunch of radio buttons with corresponding text right next to it. What I want to happen is that when the mouse is moved over the radio button, I want the text background to get highlighted. As you can see from the code below, I only get the text background highlighted when the mouse is over the text or only the radio button is highlighted when the mouse is over the radio button. How can I fix this? Thanks. -jjiimmyy101
<input type="radio" name="Pizza" onMouseover="style.background='red'" onMouseout="style.background='white'" value="Large" id="Large">
<label for="Large" onMouseover="style.background='red'" onMouseout="style.background='white'">Large</label>
<input type="radio" name="Pizza1" onMouseover="style.background='red'" onMouseout="style.background='white'" value="Small" id="Small">
<label for="Small" onMouseover="style.background='red'" onMouseout="style.background='white'">Small</label>
Technology news on Phys.org
Hi jjiimmyy101,
If you add an id value to the labels, then you can refer directly to the label properties inside the radio statements (I've called the first label AAA and the second label BBB so you can see my additions easier):
<input type="radio" name="Pizza" onMouseover="AAA.style.background='red'" onMouseout="AAA.style.background='white'" value="Large" id="Large">
<label for="Large" onMouseover="style.background='red'" onMouseout="style.background='white'" id="AAA">Large</label>
<input type="radio" name="Pizza1" onMouseover="BBB.style.background='red'" onMouseout="BBB.style.background='white'" value="Small" id="Small">
<label for="Small" onMouseover="style.background='red'" onMouseout="style.background='white'" id="BBB">Small</label>
Gee whiz. At least I knew the answer would be easy. Thank you so much :smile:
-jjiimmyy101
-jjiimmyy101
You're welcome!
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
