How Can I Separate My Polymer Reaction Product from the THF/Water Mixture?
The discussion focuses on the synthesis and purification of Cyclopentadiene functionalized polyketone from polyketone using THF and water as solvents. The main concern is how to effectively separate the reaction product from the THF/water mixture. Participants suggest that the polymer may be insoluble in THF/water, allowing for simple filtration, but also note that the product is sticky and clogs filter pores. Alternatives proposed include centrifugation and using a rotavapor to remove THF, which may help isolate the polymer. Reprecipitation into cold water after adding THF is recommended for purification. If challenges persist, further evaporation of solvents and drying under high vacuum are advised to achieve a friable solid for easier handling.
Calafalas
Hi chemistry friends,
I'm currently working on a reaction to produce the following polymer: Cyclopentadiene functionalized polyketone.
I start with polyketone as a reagent and I should end up with the reaction product together with the solvent (THF) and water with NaOH.
My question is as following: How can I separate my reaction product from the THF/water ?
Do you think that is will be insoluble in THF/water, so I can use simple filtration? Or should I use a different solvent to extract the polymer ?
Chemistry news on Phys.org
It should be much less soluble in THF/water. The more water the less soluble. You might need to add more THF or dioxane to keep it in solution long enough to complete the grafting. After that, pour the stuff into a large volume of cold water and isolate a crude solid. Dissolve in a minimum of dioxane and repeat to further purify and reduce the amount of salts in the product.
Tried to repricipitate the reaction mixture in water. Filtration doesn't seem to work however.. only for about 5 ml. Then it stops.
Any tips for this ?
The stuff is sticky and clogs your filter's pores. Try centrifuging. Or you could put the whole thing on the rotavap and remove the THF solvent. It should goo out on the glass surface eventually. Decant, add some THF and reprecip into cold water. If you still have troubles with the precipitation/filtration or centrifuging, put it back on the rotavap and remove the THF again. Dry the goo under high vacuum and hope that when the last traces of solvent and water are removed you get a friable solid so you can scrape it out, grind it and properly dry it.
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
