How Can I Set Up a Wireless Proximity Sensor With Indicator Lights?
  • Thread starter Thread starter slimmy123
    Sensor
A user seeks to set up a wireless proximity sensor that activates a green light when unobstructed and a red light when an object is detected, with a range of about one meter. Suggestions include using garage door sensors or directional PIR sensors that emit infrared rays to detect objects. For wireless signal transmission, the user considers inexpensive modules but needs guidance on implementation. The discussion highlights the need for a simple PLC to manage the sensor's output to the indicator lights. Overall, the focus is on finding suitable sensors and solutions for wireless communication to achieve the desired functionality.
slimmy123
Proximity sensor devise HELP !
Hi all I'm new on here and this is my first post,
I would like to set up a sensor devise where when there isn't a object in the way of the sensor there will be a green light on a panel the other side of a building and when a object moves into the way of the sensor the green light will turn off and a red light will turn on on the same panel. From browsing the net I've gathered i'd need some sort of proximity sensor with a cat5 cable wired back to the panel. Also i'd like to add i only want the sensor to have a metre or so range and be direct not a spread out range like a PIR.
If anyone knows of any products that are out there that would suit this plan or any information on how or wether it would work would be great. Also if this could be done wirelessly it would save the hassle of wiring!
Any help would be great. Thanks
Welcome to the PF.
In response to a similar thread a week or so ago, a person came up with a great idea -- how about the sensor that is used on garage doors to stop the door coming down when somebody walks into the doorway? It's an optical beam of some sort, with a transmitter on one side, and the receiver on the other (or maybe there are some with both TX and RX together on one side, and only an optical cube corner at the other side. Would something like that work for you?
There are lots of sensors out there that will do what you want. Check out SMC and Banner for some starting places. You can find both through beam and reflective sensors that will serve your purpose. The problem of sending the result to your display lights is a separate one. CAT5 implies a LAN connection which implies a computer or 2 involved. It may be cheaper and simpler to get a simple PLC to read your sensor state and set the correct indicator state. You will need wires running the distance between.
hay berkeman and integral cheers for the replys.:smile:
ye i thought about the garage door sensors but i want the sensor on the ceiling and couldn't have another sensor on the floor as it would be a trip hazzard! health & safety ay!:zzz: lol. good idea in principle but i haven't got a clue about where to start really! may have to get a design company involved i think!
There are types of PIR sensors that only have about a metre range, and are very directional. I saw them in this package: Click here for DigiKey link
Basically, there are two types: MP and MA. You would be looking at the MA type, quote: "... this sensor emits infrared rays from an LED. Using the reflection of those rays, the sensor measures the distance to the person (object) and detects whether or not it exists within a specific distance."
Take a look at it :)
wetmelon that's a brilliant bit of information i really do appreciate it.
Do you know how i could send this signal from the motion sensor to a panel wirelessly? i was thinking of these somehow as there cheap! http://www.maplin.co.uk/Module.aspx?ModuleNo=267236 do you think this would work.
once that problems solved i have to sort out the panel end!
as i say any help will be great.
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
