How Can I Show That \( \exp(-iaP/\hbar) = U \)?
  • Thread starter Thread starter naggy
    Momentum Operator
naggy
If U is an operator so U\Psi(x) = \Psi(x-a).
How can I show that exp(-iaP/h) = U
where P is the momentum operator P = -ih(d/dx)
Not sure
What I do know that if I have a function F of an operator then
F(P)\psi = $\sum_{i} c_iF(\lambda_i)\psi_i
where \lambda_i are the eigenvalues of P
and c_i = <\psi_i,\psi>
can I somehow relate all of this to the operator U
I think what you'll want to do is combine the fact that (by the definition of the exponential of an operator)
e^{-iaP/\hbar}=\sum_{n=0}^{\infty}\frac{(-1)^na^nP^n}{\hbar^n n!}
with your expression for P in the x-basis to calculate e^{-iaP/\hbar}\Psi(x)...your result should remind you of a Taylor series!:wink:
Ok so:
e^{-iaP/\hbar}= e^{-aD_x} = 1 - aD_x + \frac{a^2D_x^2}{2!} - \frac{a^3D_x^3}{3!} + ...
and applying this to \psi(x) I can´t really say that I recognise the series, but I suppose it is the series for shifted \psi(x) about a
It's given a gas of particles all identical which has T fixed and spin S. Let's ##g(\epsilon)## the density of orbital states and ##g(\epsilon) = g_0## for ##\forall \epsilon \in [\epsilon_0, \epsilon_1]##, zero otherwise. How to compute the number of accessible quantum states of one particle? This is my attempt, and I suspect that is not good. Let S=0 and then bosons in a system. Simply, if we have the density of orbitals we have to integrate ##g(\epsilon)## and we have...
