How Can I Solve a System of Equations With Complex Numbers?
To solve the system of equations involving complex numbers, the equations 2z + w = 7i and zi + w = -1 can be manipulated similarly to real numbers. By eliminating w through subtraction, the equation simplifies to (2 - i)z = 1 + 7i. Dividing both sides by the complex number (2 - i) leads to the solution z = (-1 + 3i) and w = (2 + i). Understanding how to divide complex numbers is crucial for obtaining the correct solutions. The discussion emphasizes the importance of manipulating equations correctly and knowing complex number operations.
Callmelucky
How can I solve a system of equations with complex numbers
2z+w=7i
zi+w=-1
z=a+bi
2z+w=7i
zi+w=-1
I have tried substituting z with a+bi and I have tried substituting w=7i-2z but didn't get anything useful.
Edit: also, I've tried, multiplying lower eq. with -1 so that I can cancel w but I get stuck with 2z and zi and I can't figure out what I am supposed to do with that.
Edit2: also, I have tried replacing both z and w with a+bi but still nothing
Thank you
2z+w=7i
zi+w=-1
Are you sure you've typed that correctly?
yes, and the solution should be z=-1+3i, w=2+i
You can manipulate complex numbers very much like you are used to with real numbers.
So what you tried should give you 2z-zi = 7i-1. Then you can factor the left side to get z(2-i)=7i-1
CORRECTION: z(2-i)=7i+1 and divide both sides by 2-i. z=(-1+7i)/(2-i). CORRECTION: z=(1+7i)/(2-i)
(Corrections thanks to @pasmith)
You can do that and work with all the reals and imaginary parts separately, but that is often the last resort.
I get these values.
You're making things harder than they need to be. Don't substitute a + ib for z. You can eliminate w by adding -1 times the second equation to the first. This gets you a simple equation involving only z. Then back-substitute to find w.
FactChecker said:
So what you tried should give you 2z-zi = 7i-1. Then you can factor the left side to get z(2-i)=7i-1 and divide both sides by 2-i. z=(-1+7i)/(2-i).
I do get that, but that is not what is in solutions.
Subtracting iz + w = -1 from 2z + w = 7i should give <br /> \begin{split}<br /> (2 - i)z + (1 - 1)w &amp;= 7i - (-1) \\<br /> (2 - i)z &amp;= 1 + 7i.\end{split}
Likes Callmelucky and FactChecker
Callmelucky said:
Okay, but that still isn't z=-1+3i
Yes, it is. You need to simplify it by multiplying both the numerator and denominator by 2+i
Likes Callmelucky
I got it, that is why I deleted comment right after posting it lol :D.
Thanks everyone.
But the problem is that I did not know how to divide complex numbers yesterday, I learned that like 10 minutes ago.
Likes DaveE and PeroK
That's the key here. If you proceed as I advised back in post #5, you get ##z = \frac{1 + 7i}{2 - i}##. If you don't know how to do division by complex numbers, you can't simplify the above to get ##z = -1 + 3i##.
If you're working from a textbook, did it cover complex number division, but you didn't catch on?
But this is a task in the chapter before division, in the chapter for addition and multiplication of complex numbers.
When you get: z=(-1+7i)/(2-i).
multiply by (2+i)/(2+i)
That seems odd. You didn't show the complete problem as it appears in the book -- were you supposed to solve for z and w, or was it something simpler, like saying that there is a solution vs. saying that there is no solution?
This works (although you can't replace both z and w with a + bi -- you need to replace w with a different complex number), but it entails knowing how to solve a system of four equations in four unknowns.
Likes Callmelucky
Take the result @pasmith gave in Post#7, shown below.
Now multiply both sides by the complex conjugate of ##(2-i)##.
You will need to be able to divide both sides by ##5## to arrive at the answer..
No, it says: solve systems of equations. And then 3 problems and that is it.
I think this was expected to be done. Because I have already seen how it was supposed to be done just couldn't remember
Yeah, if you write the system as an augmented matrix -- 4 rows and 5 columns, and do reduced row-echelon reduction, the solution comes out pretty easily.
Likes Callmelucky
Yes that is one easy way without needing complex division - ISTR that multiplying by a complex conjugate was a common tool in solving exam questions at this stage.
It is also easy to solve by setting ## z = a + ib, w = c + id ## and solving for the real and imaginary parts separately: you should get to e.g. ## 2a + b = 1, 2b - a = 7 ## quickly and it is trivial from there.
Likes Callmelucky
