How can i stick metal nanoparticles on glass?
  • Thread starter Thread starter nadaben
    Glass Metal
To characterize metallic nanoparticles using Scanning Electron Microscopy (SEM), depositing them on a substrate is essential. However, using a glass substrate can be problematic as glass is an insulator, leading to charging issues during SEM imaging. A concentrated nanoparticle solution is necessary for effective drop casting; if the solution appears colorless, it may not be concentrated enough. Alternatives to SEM include Transmission Electron Microscopy (TEM) for structures under 100 nm and Atomic Force Microscopy (AFM), though distinguishing nanoparticles from contaminants can be difficult. The layer-by-layer (LBL) method is suggested as a potential solution for better deposition.
nadaben
to caracterize for exple metallic nanoparticles with SEM i should deposite them on a substrate
i tried a deposition on glass substrate but it doesn't work and i see nothing
can anyone help me or suggest an appropriate solution to that
best regards
Chemistry news on Phys.org
Your previous posts have indicated you're trying to make colloidal gold. Do you know the concentration of nanoparticles in your solution? If your solution is concentrated enough to be colored, you should be able to just dropcast NPs onto a glass slide. But for SEM, glass is a bad idea: it's an insulator, so it'll charge like crazy. There are ways to do non-conductive SEM, but I'm not too familiar with them (I think they involve low voltages = lower resolution). TEM might be a better option, as the structures you're looking for will probably be less than 100 nm. AFM is another option, but it can be challenging differentiating between nanoparticles and ordinary dirt.
Actually my solution is not that much concentrated when i deposit a drop it's almost colorless
thank you for other informations it's very interesting
Have you tried layer-by-layer (LBL) method? See references by Kotov, et. al.
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
