How can I use Pneumatic Muscles as Hydraulic Muscles?
Pneumatic artificial muscles can be converted to hydraulic systems by using water as the working fluid, with no significant issues noted in the transition. For optimal performance, a high-pressure reservoir is recommended for speed, while a low-pressure reservoir is better for power. It's crucial to vent any trapped air in the hydraulic system to prevent safety hazards due to gas compressibility. Adding antifreeze to the water can help reduce corrosion and prevent freezing, while a pressure relief valve is necessary for safety. To determine the appropriate pump, first assess the load requirements and fluid volume needed for actuation.
Warren Pnigel
Hi everyone, this is my first post
I was wondering how can I turn a pneumatic artificial muscle into a hydraulic one using water.
http://www.instructables.com/id/How-to-make-air-muscles!/ These are the air muscles I was planning on using.
What sort of pump would I need? Please be specific as I'm not very experienced with this.
Thanks!
Welcome to PF.
There is no obvious problem changing the working fluid from air to water.
If you want speed, use pneumatics with a high pressure reservoir. If you want power use hydraulics with a low pressure reservoir tank and pump.
Air trapped in a hydraulics system can reduce rigidity and increase danger. That is because the compressibility of gas can store more energy than a liquid. With air in the system a hose failure can empty the hydraulic fluid very rapidly. There must be a way to vent air from the system.
Add car radiator antifreeze = ethylene glycol 33% to your water, 67%. It will reduce corrosion in your pump and valve system. It also prevents freezing in winter which can damage valves and will also help identify the source of leaks.
Likes Warren Pnigel
Thanks! Just for the point of using hydraulics, I'd like to use hydraulics :D even though it sounds dumb. Can you recommend a fast pump at all?
I think your first move should be to make a "muscle" and identify the magnitude of the load that will be applied to the muscle. From that position you can measure the volume of fluid and the pressure needed to actuate the mechanism as the length changes. You will then be in a position to select a pump. You will also need some form of pressure relief or safety valve to protect the muscle.
There are a couple of topological possibilities, you could have only one pump but several valves, one valve for each muscle, or you could have a pump for each muscle, without any valves. Will the energy to drive the pump come from an electric motor?
Likes Warren Pnigel
Yes, I'll drive the pump with a motor. I already have a motor laying around which I'll use for testing, but it's not very strong. I'll probably upgrade it later.
Thankyou for taking the time to reply to this thread as well, you've helped me alot! :)
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
