How Can Nonlinear Systems be Modeled without Aliasing Artifacts?
  • Thread starter Thread starter haminous
    Digital Modeling
Modeling nonlinear systems without aliasing artifacts is challenging due to harmonic generation beyond the Nyquist frequency. Oversampling and filtering are common strategies, but designing a frequency response for sampling and inverse FFT can yield an FIR filter kernel, which may only approximate nonlinear behavior. The Harmonic Balance Method (HBM) is a suggested frequency domain approach for periodic nonlinear responses, though it can be complex due to the nature of nonlinear systems. Accurate modeling often requires validation against time domain data or measurements to avoid misleading results. The discussion highlights the difficulty of balancing time domain simplicity with the need for a more precise frequency-limited model.
haminous
So I've been having a bit of fun with FFT's of some nonlinear functions applied to sine waves and I noticed 'reflection' of the harmonics due to generation of frequencies beyond the Nyquist frequency. This comes as no surprise, but it left me wondering how one might model nonlinear systems without generating erroneous frequency components (in a guitar effects pedal, for instance). Is there a clever way to do this or does one have to 'brute force' it by massively oversampling and filtering?
If you're keenly aware of what you want to happen in the frequency domain, you might be able to design the frequency response that you want, then sample it and take its inverse FFT. The result will be an FIR filter kernel. You can convolve this with your input to get any kind of frequency-domain behavior you want, without introducing frequencies higher than Nyquist.
On the other hand, an FIR filter is a linear filter, so it can only approximate the behavior of the non-linear filter. Maybe the part that sounds good to the ear can be modeled linearly, though?
- Warren
The simplest way to model nonlinear behavour is in the time domain.
One way to do it in the frequency domain if the response is for periodic (but non-sinusoidal, and amplitude dependent) is the Harmonic Balance Method (HBM or IHBM).
On the other hand, some nonlinear systems can generate responses that are unrelated to anything in a "linearised" (small-amplitude) model of the system or the frequency of the input force, and trying to model that in the frequency domain is a seriously hard problem.
The output from any frequency domain model tends to be restricted by the assumptions you made in setting up the model, and if those don't correspond to what the real system can do the "answers" can range from useful approximations to completely wrong. You need some independent information (either a time domain model, or some measurements) to validate what you get.
There is no particular problem in having a large (even infinite) frequency range in a FD model, but (as your OP implied) you need to careful about aliasing etc when converting between the time and frequency domains. This is often an artefact of using sampled data to represent the time domain, not something that is intrinsic to "real world" analog nonlinear systems.
chroot, ...
...thanks for the suggestion, but in this case it's specifically harmonic generation due to nonlinear effects that I'm interested in analyzing so an FIR wouldn't quite do it here.
AlephZero, ...
...it's precisely those aliasing 'artifacts' that I would like to avoid for exactly the reason you stated - it doesn't represent the real world system. It seems like I'm caught somewhere between the simple time domain modeling (which is what I've been doing) and needing something that represents a more accurate frequency-limited model. Thanks for your insights. I've never heard of the HBM method before; it looks fascinating. Sounds like this is a tough problem in general. Ironically enough, I'm actually working on analysis of nonlinear harmonic generation for the purpose of making these kinds of problems simpler.
On a sidenote, does anyone know of an analog circuit that can produce either a hyperbolic tangent or logistic function of its input?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Thread 'How Does Jaguar's 1980s V12 Dual Coil Ignition System Enhance Spark Strength?'
I have come across a dual coil ignition system as used by Jaguar on their V12 in the 1980's. It uses two ignition coils with their primary windings wired in parallel. The primary coil has its secondary winding wired to the distributor and then to the spark plugs as is standard practice. However, the auxiliary coil has it secondary winding output sealed off. The purpose of the system was to provide a stronger spark to the plugs, always a difficult task with the very short dwell time of a...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
