How can ||P|| = 1 be used to show that P = P*?
buzzmath
Let P be a projection. The definition used is P is a projection if P = PP. Show that ||P|| >=1 with equality if and only if P is orthogonal.
Let ||.|| be the 2-norm
P = PP. P is orthogonal if and only if P =P*
I've proved the first part of ||P|| >= 1 and the first part of the equality portion. Assume P is orthogonal prove ||P|| = 1. However, I'm having a lot of trouble with the second part: Assume ||P|| = 1 show P is orthogonal.
Can someone point me in the right direction or suggest any ideas on how to use ||P|| = 1 to show that P = P*?
I've been playing around with inner products to try to solve this part but haven't gotten anything good out of it that uses the fact that ||P|| = 1
I know that the square roots of the nonzero eigenvalues of P*P or PP* are the singular values of P and thus also P*. The ||P|| = max{singular value} thus P and P* have the same 2-norm. ||P||=||P*||=1.
I write <(PP*-P*P)x,x> = <P*x,P*x>-<Px,Px>=||P*x||^2-||Px||^2
||P|| = sup (||Px||) where ||x|| = 1.
Does this necessarily mean that ||Px||=||P*x||? I'm thinking the max values of both norms are equal but does that mean that they are equal for all other x values?
If that is true then <(PP*-P*P)x,x> = 0 thus PP*=P*P so P is normal
and a normal matrix is self adjoint so this would complete the last part of the proof.
Does this make sense? I'm worried because I don't really use the fact that ||P|| = 1
I was thinking that maybe since the norm is 1 that could maybe imply ||P*x||=||PX|| and then I would follow as above.
I'm not sure if this is the right direction to go in or if I'm way off.
Thanks for any help
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
