How can the simplification of equation I.4 using equation I.5 be justified?
The discussion focuses on justifying the simplification of equation I.4 using equation I.5 by canceling the coordinates of C. It is noted that while attempting to eliminate C2 through differentiation, the process leads to expressions that still involve C2, suggesting a misunderstanding of the cancellation process. The user outlines a method of differentiating I.4 with respect to A1 and B1 to derive relationships involving C2, ultimately aiming to eliminate all C variables. The conclusion drawn is that through repeated differentiation and application of equilibrium conditions, one can arrive at a simplified relationship between θA and θB. The thread emphasizes the importance of understanding the underlying mathematical principles in this simplification process.
Aniket1
I was studying zeroth law from MIT Courseware (http://ocw.mit.edu/courses/physics/...-fall-2013/lecture-notes/MIT8_333F13_Lec1.pdf). On page 2, it is mentioned that equation I.4 can be simplified using equation I.5 by cancelling the co-ordinates of C. Could someone guide me justify this fact? I tried working it out by assuming functions and I could construct functions where equation I.4 and equation I.5 are satisfied but it is not possible to cancel C. Am I missing something?
Equation I.4 does not contain C1. Now let' eliminate C2. Differentiate I.4 with respect to A1, then you will get
F#AC(A1,A2,...,C2,...)=0
But then you can write this equation as C2=GAC(A1,A2,...,C3,C4,...).
Similarly, differentiate I.4 with respect to B1. Then you will get
F#BC(B1,B2,...,C2,...)=0
But again you can write it as C2=GBC(B1,B2,...,C3,C4,...).
Since there is equilibrium then,
GBC(B1,B2,...,C3,C4,...) = GAC(A1,A2,...,C3,C4,...).
Thus, you eliminated C2. Repeat the procedure unti you eliminate all C's . Then you will end up with
θA(A1,A2,...)=θB(B1,B2,...).
Likes Aniket1
Thread ''splain this hydrostatic paradox in tiny words'
This is (ostensibly) not a trick shot or video*. The scale was balanced before any blue water was added. 550mL of blue water was added to the left side. only 60mL of water needed to be added to the right side to re-balance the scale. Apparently, the scale will balance when the height of the two columns is equal. The left side of the scale only feels the weight of the column above the lower "tail" of the funnel (i.e. 60mL). So where does the weight of the remaining (550-60=) 490mL go...
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
