High School How can the Universe be flat? Ridiculous
The discussion centers on the concept of the universe's geometry, specifically addressing the idea of a "flat" universe. Flatness refers to the behavior of parallel lines, such as light beams, which remain parallel in a flat universe, contrasting with open and closed universes where lines diverge or converge. While current measurements suggest the universe is flat, it is not definitively proven, and other topologies could exist. The observable universe, which can be conceptualized as spherical from an observer's perspective, is distinct from the universe as a whole, which may not have a defined shape or boundaries. The conversation emphasizes the importance of distinguishing between the observable universe and the broader universe in cosmological discussions.
JackB123
The earth is a sphere. I can stand anywhere on its surface and look up directly above my head at the night sky and see lots of stars many light years away. I see this view wherever I stand on the earth's surface although the stars will be different ones, depending on where I'm standing. Therefore I am confident that my planet is a little sphere surrounded by a massive sphere of space containing stars. So what is all this nonsense about the universe being flat?
  • Skeptical
  • Haha
  • Sad
Likes Motore, malawi_glenn, weirdoguy and 1 other person
Astronomy news on Phys.org
The flatness here refers to the geometry of space. It doesn't mean the universe is somehow a two-dimensional sheet (as it obviously isn't). It means that two parallel lines going through the universe - like two light beams for example - remain parallel forever.
Likes collinsmark, DennisN, pinball1970 and 4 others
You should not be confident of that because it is incorrect. The universe is not at all likely to be a 3D sphere since it does not have a center or an edge. It might be infinite or it could (but is not likely to be) some unknown topology.
Also, to add to what @Bandersnatch correctly said, it is not a hard fact that the universe is flat. It is known to be flat to within pretty much our ability to measure it, and it almost certainly IS flat, but it is possible that it is not flat.
Likes Vanadium 50, pinball1970, malawi_glenn and 1 other person
There are three types of universe described by the Einstein field equations, called open, flat and closed. Which type you have depends on the average density of matter in the universe. Note that all of these are four dimensional structures, and while you may see them illustrated as sheets of paper or the surface of a beach ball this is because drawing 4d structures always requires some simplification - in this case to just 2d. Don't mistake such sketches for the actual models.
In open universes initially parallel lines diverge, in flat universes they remain parallel, and in closed universes they converge and eventually cross twice before returning to where they started (the similarity to lines of longitude on a globe is not coincidental). Closed universes are finite in size but boundaryless (did I get the terminology right that time @Bandersnatch?) and can eventually collapse into a Big Crunch (depending on the dark energy content), but the other two are infinite in size and expand forever. Our best measurements suggest we live in a flat universe, but we could live in one of the others if the scale of the curvature is so large that the observable universe is too small a patch for us to detect the deviation from flatness.
Likes Bandersnatch and malawi_glenn
Earth is not a sphere
Thank you phinds for your very knowledgeable reply. Although I think my statement 'therefore I am confident that my planet is a little sphere surrounded by a massive sphere of space containing stars' is actually not incorrect. I did not say that the universe was a 3D sphere. In the context of the rest of my post, I said that an observer standing at multiple points on the earth's surface and looking upwards sees a massive sphere of space in which are many stars, I said nothing about what may be beyond his sphere of vision. I am just trying to conceptualize the shape of the universe in the same way as I can conceptualize the shape of our solar system, which is a 3D structure of orbiting planets in space, of which plastic models can be made. Is it actually impossible to do this for the universe, even at just one moment in time?
Yes.
It might have been better to call it a "parallel beams" universe. Parallel beams of light in a vacuum and no gravity stay parallel. In other geometries the beams either converge or diverge.
What you are talking about here is called the observable universe which is the part of the universe that we can, in principle, see. Whether this is exactly spherical or not depends a bit on definitions and details that don't matter here. But a major source of confusion in writing about cosmology is failing to distinguish claims about the universe from claims about the observable universe.
Likes collinsmark
That's pretty much the definition of "flat" isn't it? The spatial part of the metric in the flat case is actually just Euclidian.
Sure. I'm trying to help out the OP.
Thank you for indulging my anal-retentiveness. It is appreciated.
Ibix said:
initially parallel lines ....in closed universes they converge and eventually cross twice before returning to where they started
I can see how theoretical that probably is but what is the point to which they return?
Is it a point in space or a point in spacetime?
If the starting point is Las Vegas with Sinatra doing a residence do the parallel lines return to knock off his hat or has he long departed along with his gang of entertainers and only the space remains?
Can the parallel lines be two beams of light or is this just a geometric model/construct?
They're lines along a plane of constant cosmological time, so they're just circles around the (model) universe. They're exactly like lines of constant longitude on a globe, except there are three orthogonal directions you can draw them in, not two.
This is just geometry and the lines are spacelike. If you want to send out light rays they follow null paths, not spacelike, but you can do it. They may not have time to circumnavigate the universe before the Big Crunch (depends on the dark energy content), and even if they do then issues about "where will you be in several trillion years" do arise in that case. You would need to be a co-moving observer in a true FLRW model universe for the light paths to project onto spacelike planes as neatly as circles on a globe, but you can (in principle) see the back of your head in the far distance in a closed universe that is sufficiently long-lived.
  • · Replies 0 ·
  • · Replies 47 ·
  • · Replies 29 ·
  • · Replies 25 ·
  • · Replies 106 ·
12K
  • · Replies 25 ·
