I How can the Universe be infinite?
The universe began in a "hot, dense" state rather than as a singular point, which is a common misconception. It has been expanding for 13.7 billion years, leading to questions about its infinite nature. Two possibilities arise: the universe could be much larger than the observable universe or it could be infinite, having always been so. The observable universe is finite, but depending on the cosmological model, the entire universe may be finite and large or infinite. Understanding these concepts requires careful consideration of physics rather than simplified explanations.
Meow12
The universe started off as a point and has been expanding for 13.7 billion years. Since this is a finite amount of time, how can the universe be infinite?
Astronomy news on Phys.org
It didn't. This is is a common misconception. It started out in a "hot, dense" state.
There are two possibilities: either the universe is much larger than the observable universe or the universe is infinite. If it's infinite, then it has always been infinite - even when it was initially hot and dense.
It did not so any logical inference from that is not going to tell you anything about the actual physical model.
Some sources are sloppy about the distinction between the universe and the observable universe (which is the part of the universe we can see, more or less), and also which cosmological model they are talking about.The observable universe is finite and was small in the past, although "started as a point" is a bit dubious for various reasons. Depending on which cosmological model you are talking about the universe may be finite and very large, in which case it was small in the past too, or it may be infinite, in which case it always was.
Just listen to the theme song from "The Big Bang Theory" show. "The whole Universe was in a hot dense state."
As said above, this is a common misconception. Try reading actual physics instead of pop-sci presentations.
You might be interested in this thread that I started recently.
It does go around in circles a bit (by "it" here, I mean "me") but ultimately it (and by "it" here, I mean the knowledgable PF members that weighed in with nigh-infinite patience) explains how a universe can be infinite in extent - and yet still expand.
