- #106
AKG
- 2,567
- 4
I don't know the answer to this one yet, but I'll post it:
Prove that if an element of a ring has at least two right inverses, it has infinitely many
Recommended steps:
If an element b of a ring has N right inverses (N > 1), then bx = 0 has N+1 solutions
If b has at least N right inverses, it has at least N+1
The following isn't a solution, it's just what I've thought of so far:
It's clear how the first hint implies the second, and how the second proves the desired result. Now this problem was from a combinatorics class, so given N right inverses, there is some way to combine them to get a number of solutions to bx = 0, and we probably need to use some combinatorial argument to count the number of such solutions.
If x, y, z are distinct right inverses, then 0, x-y, y-x, y-z, z-y, x-z, z-x are solutions to the homogeneous equation. We know that at least 0, x-y, and x-z are distinct. We are left with four things, y-x, y-z, z-y, and z-x. And none of these are zero. So if we assume that there are only 3 distinct solutions to the homogenous equation, then we get that the pigeons:
y-x, y-z, z-y, z-x
must fit into the pigeon holes
x-y, x-z
It's also clear that y-x and y-z can't go in the same hole. Likewise, z-y and z-x can't be in the same hole. Now if you put y-x in the first hole, then it contains both x-y and y-x. Hence for every a-b in that hole, b-a is in that hole. This will lead to contradictions. So you must put y-x in the second hole, and y-z in the first, giving:
{0}, {x-y, y-z}, {x-z, y-x}
and z-x, z-y yet to be placed. It's clear, by the contradictions mentioned above which arise by putting a number and it's additive inverse in the same hole, that we must get:
{0}, {x-y, y-z, z-x}, {y-x, z-y, x-z}
Does this give a contradiction? Moreover, how can this be generalized to n > 3?
Recommended steps:
y-x, y-z, z-y, z-x
x-y, x-z
