How Can We Simplify the Algebra in Relativistic Elastic Collision Problems?
The discussion focuses on simplifying algebraic expressions in relativistic elastic collision problems by leveraging conservation laws. Participants suggest avoiding complex variables like p' by using conservation of energy and momentum separately. It is recommended to express momentum in terms of energy and known parameters to streamline calculations. Squaring the relevant 4-vectors can help eliminate square roots, potentially leading to a solvable quadratic equation. Overall, the emphasis is on reducing algebraic complexity while maintaining accuracy in calculations.
yup790
et Em and pm be the energy and momentum of the mass m after the collision. Let p and p' be the momentum of mass M before and after the collision.
From conservation of 4 momentum:
\begin{bmatrix}E+m \\ p\end{bmatrix}=\begin{bmatrix}E_m+E' \\ p'+p_m\end{bmatrix}
We also have our invariants
E2-p2=M2, etc.
Squaring the 4-vectors we get: E^2+2Em+m^2-p^2=E'^2+2E'E_m+E_m^2-p'^2-2p_mp'-p_m^2
Using our invarients, this becomes:
M^2+m^2 + 2Em=m^2+m^2+2(E&#039;E_m-p&#039;p_m)<br /> \implies Em=E&#039;E_m-p&#039;p_m<br />
now, using the conservation of energy and momentum:
E_m=E+m-E&#039; & p_m=p-p&#039;
Substituting these in and using our invarient again gets us:
Em=E&#039;(E+m)-p&#039;p-M^2
I have tried setting p=\sqrt{E^2-M^2}however its gets so algebraically heavy. Is there an easier way??
You can make a stronger statement. Energy and momentum are both conserved separately. That way you can avoid p' with its ugly influence on the equations.
What would I replace it with? p-pm is a bit redundant
p-pm is fine. Express pm in terms of Em, then replace it by E' and known parameters. Squaring it at the right place will get rid of any square roots, and then you'll probably have to solve a quadratic equation.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
