How Can You Build an Effective Air Cannon to Extinguish Candles from a Distance?
The discussion focuses on creating an air cannon to extinguish candles from a distance using a vortex ring launcher, adhering to specific guidelines. Participants explore various materials and designs, emphasizing the need for creativity without using commercial devices or compressed air. Suggestions include using a trash bag and rubber bands, or a traffic cone as a barrel. The original poster seeks innovative ideas beyond basic models like trash cans and coffee cans. Overall, the conversation highlights the challenge of building an effective air cannon while complying with strict project rules.
hamilton4prez
Physics air cannon project
task: Extinguish candles on tables using a vortex ring launcher/ air cannon
rules: No dimension over .305 m
cannon is placed 1-6 m from target
*no foreign objects may be used to help it fire
6 candle targets at increments of 1 meter distancing away from the cannon
30 seconds to extinguish each target
must propel vortex ring of air at the target
*no commmercially made devices
*no explosive substances
*no cartridges or compressed air
*no electricity
although i have a basic understanding of this assignment, i am curious to hear suggestions and hints from brains more intelligent and experienced than mine have to offer. How yould you approach your model? What materials would you use? What is the most efficient method that follows under the guidelines listed above? Please help, my physics grade depends on it.
I have gone through basic trash can and coffee can models, but these seem to be cliche and mediocre.
Thank you!
*no electricity
Thank you!
Welcome to the PF.
How can you do this without compressing air? Do they allow you to pump it up?
Can you detail some of the solutions you have looked at so far? What do you want to improve on?
It sounds like you want to build something similar to the "Airzooka Air Gun"
This can be made with a trash bag, some rubber bands, and a barrel of any kind.
I think that a traffic cone with the end cut off would make a pretty neat looking barrel.
I hope this helps,
Beaker87
Thank you very much beaker87! Very appreciated
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
