How Can You Measure Outdoor Temperature Using Only Wood Blocks and Tape?
  • Thread starter Thread starter persian52
    Hard Sound Waves
An experiment to measure outdoor temperature using only wood blocks and a stopwatch can be designed by utilizing the speed of sound, which varies with temperature. By clapping the blocks together 200 meters from a wall and timing the echo's return, one can calculate the speed of sound. This speed can then be used in the formula v=332m/s + 0.59T to solve for the temperature T in degrees Celsius. To improve accuracy, multiple clap-echo cycles can be averaged to minimize timing errors. This method effectively allows temperature measurement without any liquids or additional materials.
persian52
Design an experiment to determine the temperature outside.
Materials:
2 blocks of wood
stop watch
Measuring tape
I believe it has something to do with measuring the rate of flow of a viscous liquid down a ramp.
The colder the temperature, the less distance per second the fluid travels.
Once baselines are established at known temperatures, it would be a fairly reliable instrument.
BUT
the thing is we can't use any type of liquid!
we have to do it with all the materials we have and nothing else...
my first impulse is to say thermal expansion, but I don't know what you'd need the stopwatch for. You could just leave one block outside and one inside for a really long time, but you'd also have to know the temp inside for this to work:
http://en.wikipedia.org/wiki/Thermal_expansion
But then, you're title has nothing to do with thermal expansion.
i got ur point, true
Not sure if anyone cares, but to measure the temperature outside with this equipment, one could determine the speed of sound, which varies with temperature according to v=332m/s + 0.59T, where T is the temperature in degrees celcius.
Using the equipment, clap the boards about 200m from a wall, and measure the time taken for the echo to return (a trip of 400m). To make more accurate measurements, set up a rhythm of clap-echo-clap-echo and measure multiple trips. The averaging will minimize start and finish reaction time delays. Counting 20 round trips for example, that's 20x400m = 8000m in whatever time is measured with the stopwatch. v=d/t will give you the speed of sound on that day. Then use the speed of sound equation and solve for T, the temperature.
Cheers!
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
