How Can You Solve for $a_n$ in the Sequence Given $2S_n = a_n + \frac{1}{a_n}$?
  • MHB
  • Thread starter Albert1
  • Tags
    Sequence
In summary, a sequence is a list of numbers that follow a specific pattern or rule. $a_n$ stands for the nth term in a sequence, where n represents the position of the term in the sequence. To find $a_n$ in a sequence, you need to first identify the pattern or rule and then use it to find the missing term at position n. $a_n$ can be a decimal or fraction, depending on the pattern or rule of the sequence. There are also different methods for finding $a_n$, such as using a formula, creating a table, or finding a recursive relationship.
Albert1
1,221
A sequence {$a_n$},$S_n=a_1+a_2+-----+a_n$,for each $n\in N, a_n>0$
if $2S_n=a_n+\dfrac {1}{a_n}$
please find $a_n=?$ (express in $n$)
Mathematics news on Phys.org
I claim the sequence is $1,\sqrt2-1,\sqrt3-\sqrt2,\sqrt4-\sqrt3,\dots$ and thus the general term is
$$a_n=\sqrt n-\sqrt{n-1}$$
$$2S_n=a_n+\dfrac{1}{a_n}\implies S_n=\dfrac{a^2_n+1}{2a_n}$$
Proof by induction:
We have
$$1+(\sqrt2-1)+(\sqrt3-\sqrt2)+\dots+\sqrt{n}-\sqrt{n-1}=\sqrt n$$
$$S_{n+1}=\dfrac{(\sqrt{n+1}-\sqrt{n})^2+1}{2(\sqrt{n+1}-\sqrt{n})}$$
$$=\dfrac{n+1-2\sqrt{n+1}\sqrt{n}+n+1}{2(\sqrt{n+1}-\sqrt{n})}$$
$$=\dfrac{2(n+1)-2\sqrt{n+1}\sqrt{n}}{2(\sqrt{n+1}\sqrt{n})}$$
$$=\dfrac{2\sqrt{n+1}(\sqrt{n+1}-\sqrt{n})}{2(\sqrt{n+1}-\sqrt{n})}=\sqrt{n+1}$$
It follows that $a_n=\sqrt{n}-\sqrt{n-1}$.
Proof by induction:
We have
thanks greg1313:
very good!your answer is correct
$given: \,\, 2S_n=a_n+\dfrac{1}{a_n}---(1)\\$
$for \,\,n=1\\$
$S_1=a_1=1\\$
$for \,\,n\geq 2\\$
$a_n=S_n-S_{n-1}---(2)\\$
$put \,\, (2)\,\, to \,\,(1)\\$
we have :$S_n^2-S_{n-1}^2=1\,\,\therefore S_n^2=1+n-1=n\\$
$\therefore S_n=\sqrt n$
from (2):$a_n=\sqrt{n}-\sqrt{n-1}$ #
Albert said:
thanks greg1313:
$for \,\,n=1\\$
$S_1=a_1=1\\$
$for \,\,n\geq 2\\$
A few points:
Albert, you seem to assume $a_1=1$ in your proof, or at least did not clearly show this to be true. What I would do here is state:
\(\displaystyle 2S_1=a_1+\frac{1}{a_1}\tag{1}\)
\(\displaystyle S_1=a_1\tag{2}\)
Subtracting (2) from (1), we obtain:
\(\displaystyle S_1=\frac{1}{a_1}\)
Now, substituting for $S_1$ into (2), we have:
\(\displaystyle \frac{1}{a_1}=a_1\implies a_1^2=1\implies S_1^2=1\)
Now, observing that:
\(\displaystyle S_n-S_{n-1}=a_n\), we may write:
\(\displaystyle 2S_n=S_n-S_{n-1}+\frac{1}{S_n-S_{n-1}}\)
from which we obtain:
\(\displaystyle S_n^2-S_{n-1}^2=1\)
And from this, we may write:
\(\displaystyle S_n^2-S_1^2=\sum_{k=2}^n\left(S_{k}^2-S_{k-1}^2\right)=\sum_{k=2}^n\left(1\right)=n-1\)
And from this we get:
\(\displaystyle S_n^2=n\)
Given $0<a_1$, we find:
\(\displaystyle S_n=\sqrt{n}\)
Hence:
\(\displaystyle a_n=\sqrt{n}-\sqrt{n-1}\)
FAQ: How Can You Solve for $a_n$ in the Sequence Given $2S_n = a_n + \frac{1}{a_n}$?
What is a sequence?
A sequence is a list of numbers that follow a specific pattern or rule.
What is $a_n$ in a sequence?
How do you find $a_n$ in a sequence?
To find $a_n$ in a sequence, you need to first identify the pattern or rule that the sequence follows. Then, you can use this pattern to find the missing term at position n in the sequence.
Can $a_n$ be a decimal or fraction?
Yes, $a_n$ can be a decimal or fraction depending on the pattern or rule of the sequence. Some sequences may have all whole numbers, while others may have decimals or fractions.
Are there different methods for finding $a_n$ in a sequence?
Yes, there are different methods for finding $a_n$ in a sequence depending on the type of sequence. Some common methods include using a formula, creating a table, or finding a recursive relationship.
