How Can You Solve for x When L1 and L2 are Parallel?
To solve for x when L1 and L2 are parallel, the equation derived from the angles of the polygon is 12θ + x = 360. By substituting θ with values that are multiples of 5, the solution reveals that x equals 120 when n equals 4. An alternative method involves calculating x as 180° minus the difference between the angles, leading to the same conclusion. The drawing's lack of scale is noted, but it does not affect the solution. Ultimately, x is confirmed to be 120, aligning with the provided answer key.
david3305
Find x. L1 and L2 are parallel
Choices:
a)100
b)120
c)140
d)150
e)135
From the image, the angles of the polygon in blue should satisfy:
6θ + 90 + 4θ + 2θ + 90 + x = 540
12θ + x = 360
x = 360 - 12θ
I couldn't figure out how to advance from there so I resorted to a dirty trick using the values from the choices.
Noticing that every value of each choice is a multiply of 5 then the value of θ in the equation must be:
θ = 5n
So it follows that:
x = 360-12(5n)
Then by trial and error:
x = 180 for n = 3
x = 120 for n = 4
x = 60 for n = 5
From the image x should be obtuse so then I conclude that x must be equal to 120
and the answer would be the letter 'b'. I know I got it right cause my book says that's the correct answer. However since this is a section of my book were no development of the solution is presented (just the final answer) I'm asking for some tips on other methods to solve this. Perhaps I'm overlooking something...
Thanks in advance.
I found it most efficacious to solve for ##\theta## first. Note that from the lower left moving rightward on L2 you can follow the turns until you're moving leftward along L1 and you will have turned ##180^\circ## by a sequence of angles ##\theta, 2\theta, 3\theta, (7-4)\theta##. So with that you can solve for ##\theta##.
I also note that the drawing is very much not to scale w.r.t. angles.
Likes david3305
Nice. I didn't look it that way, 'follow the turns', cool. Thank you for your reply.
I'm interested to see another way of solving for X that doesn't involve using the polygon like I did.
And yes, the drawing is not to scale at all.
If the lower θ and upper 4θ were both zero, then X would be 180°, so the answer is whatever the upper one is less the lower one, subtracted from 180°. So without solving for θ (which jambaugh already did) it looks to me like X = 180° - (4θ - θ), or 180° - 3θ.
Unless I'm reading this wrong.
Does that help?
yeah tbh I was kinda lazy to think about it, just following jambaugh's way I can find the following is true:
(θ) + (90) + (180 - x) + (90 - 4θ) = 180
-3θ + 360 - x = 180
180 - 3θ = x
By the same reasoning we already know:
θ + 2θ + 3θ + 3θ = 180
9θ = 180
θ = 20
so:
180 - 3(20) = x
x = 120
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
