How do additives in ice change Latent Heat of Fusion?
In summary, when using ice to keep a room or a cooler cold, it is best to use ice with a high specific heat capacity and a high latent heat of fusion. Adding salt to ice will lower its melting point and make it melt faster, but mixing salt with water and freezing it will actually make the ice melt slower due to the increased number of molecules in the solution. Using different types of salt, such as KCl instead of NaCl, will not significantly affect the melting time. To slow down the melting of ice, substances with high specific heat capacity or high latent heat of fusion, such as glycerol or calcium chloride, should be added.
EngSci
When using ice to keep a room (or in my case, a cooler) cold, one would want it to have a high specific heat capacity and a high latent heat of fusion, so that it would absorb a lot of energy as it melts. Basically, so that it melts as slowly as possible.
I know that adding salt to road ice will lower the melting point of the ice, making it melt faster. But what if you were to mix salt with water and then freeze it? To me it would make sense that the ice melts sooner than ice made from pure water, because of the lower melting point. However, after doing some research I've found that the opposite is true, and that salt-ice takes longer to melt than water ice.
Why does this happen? If KCl was used instead of NaCl, would that make the ice melt more slowly, or less slowly? What substances would you add to ice in order to make it melt as slowly as possible?
Thanks for the help.
Chemistry news on Phys.org
The reason that salt-ice takes longer to melt than water ice is because when the salt and water are mixed together, the salt particles increase the number of molecules in the solution, which makes it harder for the ice to absorb heat. This is because the molecules of the salt compete with the water molecules for the heat energy and the water molecules can't absorb the heat as quickly.Using KCl instead of NaCl will not make much of a difference since both salts have similar properties. To make the ice melt as slowly as possible, you would need to add a substance with a high specific heat capacity, such as glycerol, or a high latent heat of fusion, such as calcium chloride. Both of these substances have the ability to absorb large amounts of heat energy and thus keep the ice from melting quickly.
Related to How do additives in ice change Latent Heat of Fusion?
1. How do additives in ice affect its Latent Heat of Fusion?
Additives in ice can lower or raise its Latent Heat of Fusion, depending on the type of additive used. This is because additives can either increase or decrease the strength of the hydrogen bonds between water molecules, which affects the amount of energy required to break these bonds and change the state of the ice.
2. Why does adding salt to ice lower its Latent Heat of Fusion?
When salt is added to ice, it lowers the freezing point of water, causing the ice to melt. This is because the salt disrupts the hydrogen bonds between water molecules, making it easier for them to break and change the state of the ice. As a result, less energy is required to melt the ice, thus lowering its Latent Heat of Fusion.
3. Can additives in ice increase its Latent Heat of Fusion?
Yes, certain additives such as antifreeze or glycerol can increase the Latent Heat of Fusion of ice. This is because these substances form strong bonds with water molecules, making it more difficult for them to change state. As a result, more energy is required to melt the ice, thus increasing its Latent Heat of Fusion.
4. How do additives in ice affect the melting point of water?
Additives can lower the freezing point of water, causing it to melt at a lower temperature. This is because the added substance disrupts the hydrogen bonds between water molecules, making it easier for them to break and change the state of the ice. This results in a lower melting point for the ice and a lower temperature for the water to remain in its liquid state.
5. Are there any other factors that can change the Latent Heat of Fusion of ice?
Yes, the purity of the ice and the amount of pressure applied can also affect its Latent Heat of Fusion. Impurities in ice can disrupt the hydrogen bonds and lower its Latent Heat of Fusion, while increased pressure can strengthen the bonds and increase the Latent Heat of Fusion. The shape and size of the ice can also play a role in its Latent Heat of Fusion.
  • Thermodynamics
  • Other Physics Topics
  • General Discussion
