How Do Bubbles Form and Expand in Beer?
  • Thread starter Thread starter alnywk
    Beer Bubble
Bubbles in beer form due to differences in pressure, with higher pressure at the bottom causing bubble size to increase as they rise. This phenomenon does not violate the first law of thermodynamics, as the energy for bubble formation comes from the dissolved carbon dioxide in the beer. Shaking the beer introduces additional energy into the system, which can lead to more bubbles forming. The pathway of these bubbles can be analyzed using a pressure-volume (PV) diagram, illustrating the relationship between pressure and volume changes during bubble formation. Understanding carbonation is key to grasping these processes in beer.
alnywk
why there have bubble in beer,
what the pathway do the bubbles go in pv diagram
my idea :
assume temperature is constant
pressure in the bottom is higher than the suface
so the bubbles size increase
then where the energy come from?
is this action violate the first law of thermodynamics??
how about if you shake the beer, is it mean you input the energy into the system , then do it violate the 1st of thermodynamic?
Run a Google search on "carbonation" and "beer" and you will find out all you need to know about how these bubbles seem to appear from nowhere.
Thread ''splain this hydrostatic paradox in tiny words'
This is (ostensibly) not a trick shot or video*. The scale was balanced before any blue water was added. 550mL of blue water was added to the left side. only 60mL of water needed to be added to the right side to re-balance the scale. Apparently, the scale will balance when the height of the two columns is equal. The left side of the scale only feels the weight of the column above the lower "tail" of the funnel (i.e. 60mL). So where does the weight of the remaining (550-60=) 490mL go...
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
