MHB How Do Conic Sections Relate to Orbital Mechanics?
The discussion explores the relationship between conic sections derived from a double-napped cone and the energy of orbits under gravitational forces. It highlights how the angle of intersection, denoted as $\alpha$, influences the eccentricity of conic sections, which is mathematically defined. The eccentricity of orbits under gravitational influence is also linked to total energy, angular momentum, and reduced mass, demonstrating a connection between geometric properties and physical dynamics. The conversation raises the possibility of extending this relationship to other types of central forces beyond inverse-square laws. Overall, the mathematical relationship between conic sections and orbital energy is established, suggesting deeper implications in classical physics.
Ackbach
MHB
If you think about a double-napped cone, and the various non-degenerate sections you can get with it:
1. Circle
2. Ellipse
3. Parabola
4. Hyperbola,
you can see that there is a progression here: increasing angle $\alpha$ that the intersecting plane makes with the horizontal. To be clear about this, $\alpha$ is not the angle that the normal to the intersecting plane makes with the horizontal, but the angle that the plane itself makes with the horizontal.
It's also true that for an inverse-square-law force, such as gravity (in the classical limit), this same progression describes increasing amounts of energy in the resulting orbit. I've long thought there must be some mathematical relationship between the two. And there is, through the eccentricity. The eccentricity of a conic section is defined as
$$e= \frac{ \sin( \alpha)}{ \sin( \beta)},$$
where $\alpha$ is the angle I've already defined, and $\beta$ is the angle that the cone makes with the horizontal.
According to Marion and Thornton's Classical Dynamics of Particles and Systems, 4th Ed., p. 304, Eq. (8.40), you also have that the eccentricity of an orbit under the gravitational force is equal to
$$e= \sqrt{1+ \frac{2E \ell^{2}}{ \mu k}},$$
where $E$ is the total energy, $\ell$ is the angular momentum, $\mu$ is the reduced mass
$$\mu= \frac{m_{1}m_{2}}{m_{1}+m_{2}},$$
and $k=Gm_{1}m_{2}$ (the numerator of the gravitational force law, although it could also be $q_{1}q_{2}/(4 \pi \epsilon_{0})$, I suppose, for a Coulomb force.)
Hence, we have that
$$ \frac{ \sin^{2}( \alpha)}{ \sin^{2}( \beta)}=1+ \frac{2E \ell^{2}}{ \mu k}.$$
So the relationship between the angle of the conic section and the energy of the orbit is that the square of the sine of the conic section angle is affinely related to the total energy.
Likes vanhees71 and Dale
Greg Bernhardt said:
Thanks @Ackbach, what math forum can we move this to?
I would say Classical Physics.
I wonder if there is a similar relationship, more general, for any central force instead of specifically an inverse-square central force.
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
