How Do Divisors Relate in POTW #431's Integer Equation?
  • MHB
  • Thread starter anemone
In summary, the divisor formula for positive integers is a mathematical equation that calculates the number of divisors of a given positive integer. It involves factoring the integer into its prime factors and substituting them into the formula. This formula can be used for any positive integer and has applications in number theory, cryptography, and computer science. Although there are simpler methods to find the number of divisors, the divisor formula provides a deeper understanding of the calculation process.
anemone
MHB
POTW Director
3,883
115
Here is this week's POTW:
Find all positive integers $(x,\,n)$ such that $x^n+2^n+1$ is a divisor of $x^{n+1}+2^{n+1}+1$.
No one answered last week's POTW. (Sadface)
You can find the suggested solution below:
For $x=1$, $2(1^n+2^n+1)>1^{n+1}+2^{n+1}+1>1^n+2^n+1$.
For $x=2$, $2(2^n+2^n+1)>2^{n+1}+2^{n+1}+1>2^n+2^n+1$.
For $x=3$, $3(3^n+2^n+1)>3^{n+1}+2^{n+1}+1>2(3^n+2^n+1)$.
So there are no solutions with $x=1,\,2,\,3$.
For $x\ge 4$, if $n\ge 2$, then we get $x(x^n+2^n+1)>x^{n+1}+2^{n+1}+1$.
Now,
$x^{n+1}+2^{n+1}+1=(x-1)(x^n+2^n+1)+x^n-(2^n+1)x+3\cdot 2^n+2>(x-1)(x^n+2^n+1)$
because for $n=2$, $x^n-(2^{n}+1)x+2^{n+1}=x^2-5x+8>0$ and for $n\ge3$, $x^n-(2^{n}+1)x+2^{n+1}\ge x(4^{n-1}-2^n-1)>0$
Hence, only $n=1$ and $x\ge 4$ are possible.
Now, $x^n+2^n+1=x+3$ is a divisor of $x^{n+1}+2^ {n+1}+1=x^2+5=(x-3)(x+3)+14$ if and only if $x+3$ is a divisor of 14.
Since $x+3\ge 7$, $x=4$ or 11. So the solutions are $(x,\,y)=(4,\,1)$ and $(11,\,1)$.
Related to How Do Divisors Relate in POTW #431's Integer Equation?
1. What is the divisor formula for positive integers in POTW #431?
The divisor formula for positive integers in POTW #431 is n = paqbrc where n is the positive integer, p, q, and r are prime numbers, and a, b, and c are their respective exponents.
2. How is the divisor formula used in POTW #431?
The divisor formula is used in POTW #431 to find all possible divisors of a given positive integer. By factoring the integer into its prime factors, the formula can be used to determine all possible combinations of the prime factors that will result in a divisor of the integer.
3. Can the divisor formula be used for negative integers?
No, the divisor formula is only applicable to positive integers. Negative integers do not have prime factorizations, as they can be expressed as the product of a negative number and a positive number, both of which may have multiple prime factors.
4. Is the divisor formula the same as the prime factorization of a number?
No, the divisor formula is not the same as the prime factorization of a number. The prime factorization of a number only lists the prime factors of the number, while the divisor formula also includes their respective exponents.
5. Are there any shortcuts or tricks to using the divisor formula?
Yes, there are a few shortcuts that can be used when using the divisor formula. One is to only consider prime factors up to the square root of the given integer, as any factors beyond that will have corresponding factors on the other side of the square root. Another is to use a table or chart to organize the possible combinations of prime factors and their exponents.
  • Math POTW for Secondary and High School Students
