How do I algorithmically generate the nth term of this sequence?
  • Thread starter Thread starter FrankDrebon
    Sequence
The discussion focuses on generating the nth term of a sequence derived from an input vector of size n, where each term is a sum of products of n-1 components. A suggested method involves calculating the total product of all coefficients and then summing the results of dividing this product by each coefficient, while considering cases with zero coefficients. An alternative approach uses nested loops to compute the product of all coefficients except one for each term in the summation. Additionally, an explicit formula is proposed for cases with non-zero components, highlighting that the formula fails when zero coefficients are present. The conversation emphasizes the need for an algorithmic solution suitable for implementation in MATLAB.
FrankDrebon
Hi all,
I have a term in an equation that grows in an intuitive manner each time I increase the number of variables.
Basically, for an input vector of size n, this term is a sum of n terms, each of which is a product of n-1 components in the vector. Put simply, it is the sum of each unique way that the components of the vector can be multiplied together as a product of n-1 components.
I've probably explained that badly, so the first few terms can be found in the image below:
http://img52.imageshack.us/img52/1779/cvalues.jpg
It is fairly easy to compute the next term myself. However, I'd like to be able to find an algorithm for generating the nth term for inclusion in a MATLAB script.
Essentially the problem boils down to "how do I generate the nth term algorithmically?" I've run out of ideas, but can't help but think there would be some (relatively) simple matrix operation that could generate this. Maybe the pattern-hunters amongst you will notice something I haven't.
Any thoughts or suggestions welcome!
Mathematics news on Phys.org
FrankDrebon said:
Hi all,
There is a trivially simple way to approach this. Notice that any term in your equation is the product of all coefficients (c(i), for i=1 ... n) with the exception of one. So, you can generate the total product of all coefficients (call it T), and then just do a summation over the terms, i.e. T/c(i).
In equation form this looks as follows:
T= product of all coefficients c(i) for i=1 ... n
A=\sum_{i=1}^n {{T}\over{c(i)}}
So bascially you have two independent (i.e. not nested) loops. The first loop does the total product, and the second does the summation you are interested in. The only thing you have to worry about is cases where a coefficient is zero, but this is easily handled with some if statements.
If you expect no zero coefficients, then the above method is easy. If you expect cases with zeros, then you may prefer another approach as follows.
A=\sum_{i=1}^n \prod_{k \ne i} c(k)
This is also easy, but now your two loops are nested. The outer loop does a summation and the inner loop does a product calculation, but always excludes one of the coefficients.
Nice one! None of the coefficients should be zero, so I won't have to worry about that. Thanks a lot mate.
Hi, you can also find an explicit formula. If f is your function, T your product to begin with, and x_i the components, you will have f^k(x_i)=T^{\frac{(n-1)^k-(-1)^k}{n}}x_i^{(-1)^k} which can be proven inductively.
This will however only work when you originally have non-zero components. If you have more than one zero to begin with, f(x_i) = 0 for all i, and if you exactly one zero, say x_j, then f(x_i)=0 for all i \not = j, and f(f(x_i)) = 0 for all i, which is not a particulary interesting case.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
