How Do I Calculate the Position of a Mass Pole System Under Applied Force?
  • Thread starter Thread starter mabauti
    Mass Pole System
To calculate the x,y position of a mass pole system under an applied force, one must consider the torque applied at the pivot and the moment arm's length, which is specified as 11 units. The mass of the system is not defined, nor is the mass of the connecting rod, which complicates the analysis. The position over time is influenced by the moment of inertia of both the mass and the moment arm, as well as the applied torque. A transient response to an impulse input is sought, indicating a need for dynamic analysis. Understanding these factors is crucial for accurately determining the system's behavior over time.
mabauti
I want to know the x,y position at the time t of this system when I apply a force in the direction showed, how do I find it?
http://img152.imageshack.us/img152/7937/systemfr8.gif
We respectfully request students (and others) to show some effort and work.
This is a problem in which a torque is applied at a pivot to which a mass is attached by a moment arm, which in this case has length 11 (no units specified). The mass m is also not specified, and it's not clear whether or not the mass of the connecting arm (or rod) has a mass.
The position as a function of time will depend on the moment of inertia of the moment arm and mass, m, and the applied torque.
Here is a nice reference - http://hyperphysics.phy-astr.gsu.edu/hbase/mi.html
http://hyperphysics.phy-astr.gsu.edu/hbase/n2r.html#n2r
sorry for the delay Astronuc >_<.
What I want, is to know the transient response to an impulse input to that system. The length of the rod is L1 and massless
Here is something I made, can someone correct my homework?
Maybe Mabauti can calculate the solution for me, so I can see how the thing rotates in function of time.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
