How do I check if a 1x1 matrix is diagonal, lower/upper triangular?
  • Thread starter Thread starter hkBattousai
    Matrix
hkBattousai
I have an A matrix with dimensions 1x1. Its the only term a11 is an arbitrary number.
For what values of a11, this A matrix is;
  1. Diagonal
  2. Upper triangular
  3. Lower triangular
  1. Diagonal
  2. Upper triangular
  3. Lower triangular
By definition a 1x1 matrix will be upper and lower triangular. (But not strictly; for strictly upper and lower: a must be 0).
A matrix is diagonal if it is triangular and normal. Normal (for a matrix whose elements lie in the domain of real numbers) means A \ A^T = A^T \ A
A matrix is diagonal if it has no nonzero entries off the diagonal. A matrix is upper triangular if it has no nonzero entries below the diagonal. etc.
Clearly any 1x1 matrix satisfies these properties, since there are no entries off the diagonal, nonzero or not.
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
