How do I compute the commutator [L,p]?
  • Thread starter Thread starter sapplesapple
    Commutator
To compute the commutator [L, p], express the angular momentum operator L in terms of position coordinates and momentum operators. The commutator should be calculated componentwise, considering both L and p as vectors. It is essential to use the fundamental commutation relations and Levi-Civita pseudotensor manipulations to derive the result. The expression involves using Cartesian coordinates and recognizing that the momentum operator acts on the wavefunction. The calculation is more complex than initially suggested and requires careful handling of the operators involved.
sapplesapple
How do i compute the commutator [L,p]?
Read the forum guidelines.
You should know from your class that the commutator [x, y] = xy - yx
you can express the L operator in terms of the coordinates x,y,z and the momentum operator p. Apply the commutator to a wavefunction psi and simplify!
Hope that gave you a clue.
use L=rXp in the commkuator.
I find 2ihp, is that correct? do you know the correct answer?
First of all, both L and p are vectors, so the commutator should be computed componentwise. Next, you need to find a common dense everywhere domain for the commutator, it's not difficult to see that on the Schwartz space over R^3 both the momentum and the angular momentum operators are essentially self-adjoint and the invariance conditions are met. Therefore,
[L_{i},p_{j}]_{-}\psi (\vec{r})=...
and , without doing any specific calculations (derivatives i mean), using the fundamental comm. relations (also valid on the Schwartz space) and some simple Levi-Civita pseudotensor manipulations, you can find the answer.
No its more complicated than that. Use Cartesian coordinates with
[x,px]=i and (rXp)_i=epsilon_ijk x_ip_j.
r = (x, y, z) and p = (px, py, pz).
I assume you know how to take a cross product. The only other thing is that p = -i\hbarh\del which acts on the wavefunction \Psi, and you can't exchange r and p (ie. rxp is not the same as pxr)
I hope that helps
