How do I connect a button pressed signal with code in Godot 4?
  • Thread starter Thread starter Darkmisc
    godot
The discussion revolves around modifying a file explorer script in Godot 4 to change the functionality of buttons created for each file in a directory. The user initially attempted to connect a button press to a test function that prints "test" but encountered issues with the connection not triggering the print statement. Various connection methods were tried, including binding and using the connect method with different parameters, but none were successful initially. The user noted that print statements in the open_folder function did not execute, while those in the _ready() function did. Ultimately, the user resolved the issue, realizing it stemmed from a misunderstanding of another part of the code, indicating that the problem was not with the button connection itself.
Darkmisc
TL;DR Summary
I've tried connecting a button pressed signal with nBut.pressed.connect(test.bind()), but it doesn't work.
Hi everyone
I've downloaded a file explorer for Godot 4. It creates a button for every file in the open directory. When you press the button, it fills a prompt with the path to the file.
This is the code for it:
[CODE lang="python" title="open file"]nBut.pressed.connect(open_folder.bind(file_name))func open_folder(folder_name:String):
if file:
path = path.get_base_dir()
path = path + "/" + folder_name
set_layout()
[/CODE]
I'd like to modify the code so that something else happens when you press the button.
I've tried using this code:
[CODE lang="python" title="test"]nBut.pressed.connect(test.bind())
func test():
print("test")[/CODE]
The code doesn't give me an error message, but it doesn't print "test" when I press the button. The existing code, however, will run file_open.
I've also tried nBut.pressed.connect("test", self)
nButpressed.connect(self, "test")
and
nBut.pressed.connect("pressed", self, "test")
but none of these work either.
Does anyone know the correct way to do this?
I can't connect the signal in the inspector because I'm not making the buttons manually. I need code to do it because I won't know how many files (and corresponding buttons) there will be in the directory.
Thanks
It won't print when I put print commands into open_folder, although it will print if I put print commands into _ready(). Not sure why that is.
EDIT:
[CODE lang="python" title="open_folder"]func open_folder(folder_name:String):
print("A")
if file:
print("B")
set_layout()
[/CODE]
Technology news on Phys.org
Nvm. It works. Problem was that I didn't understand another part of the code.
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
