How do I determine the sign of this permutation
  • Thread starter Thread starter KodRoute
    Permutation Sign
To determine the sign of a permutation, one must count the number of inversions, defined as pairs (i, j) where i < j and σ(i) > σ(j). The discussion highlights the challenge of counting inversions in complex permutations, particularly when they are expressed in tableau form. It explains that for certain ranges of indices, the relationships can lead to either inversions or non-inversions, which complicates the counting process. The conclusion suggests that the permutation in question is likely an odd permutation, but further proof is needed to confirm this across different cases. The overall sentiment reflects a struggle with understanding permutations and their properties.
KodRoute
Find the sign of the permutation --> Picture here: http://tinypic.com/view.php?pic=2q8rkso&s=5
No other given data.
ε(σ) = (-1)^m(σ).
If i < j and σ(i) > σ(j) then there's an inversion.
Where ε(σ) denotes the sign of the permutation and m(σ) the number of inversions.
What I tried to do is this:
σ(1) = 2n + 1
σ(2) = 2n
2n + 1 > 2n -- yes
Now what? Should I go on doing the same?
I mean, if the permutation belongs directly to S2, S3 or any other number you can count the inversions but how do I count the inversions now?
Thank you.
Do you know about the "disjoint cycle notation"? This makes it a lot easier to "see" what the answer is. In this case, can you write this in cycle notation?
No I don't know what cycle notation is. However, I do know about transpositions (if that's what you're reffering to).
Thx.
If n= 1, the permutation is
\begin{pmatrix}1 &amp; 2 &amp; 3 \\ 3 &amp; 2 &amp; 1\end{pmatrix}
1 is mapped to 3 which is mapped to 1 while 2 remains unchanged. The "cycle" is (13). There is one transposition so this is an odd permutation.
If n= 2, the permutation is
\begin{pmatrix}1 &amp; 2 &amp; 3 &amp; 4 &amp; 5 \\ 5 &amp; 4 &amp; 1 &amp; 2 &amp; 3\end{pmatrix}
Notice that 1 is mapped into 5 which is mapped into 3 which is mapped back to 1 again. That is the "cycle" (153). 2 is mapped into 4 which is mapped back into 4 so another cycle is (24). Since those are disjoint, it doesn't matter which we do first- we can write this permutation as (153)(24) or as (24)(153).
In any case, (153) has two "transpositions" (swap 1 and 5 and then 1 and 3) and (24) has one "transposition" (swap 2 and 4, of course). In general, a cycle of n numbers has n-1 transpositions. So the original transposition has a total of 2+ 1= 3 transpositions, an odd number.
If n= 3, this is
\begin{pmatrix}1 &amp; 2 &amp; 3 &amp; 4 &amp; 5 &amp; 6 &amp; 7 \\ 7 &amp; 6 &amp; 5 &amp; 1 &amp; 2 &amp; 3 &amp; 4\end{pmatrix}
1 maps into 7 which maps into 4 which maps into 1 again so one cycle is (174). 2 maps into 6 which maps into 3 which maps into 5 which maps into 2 so another cycle is (2635). The first cycle has two transpositions and the second has 3 so there are 2+ 3= 5 transpositions. This is also an odd permutation.
Looks to me like this is always an odd permutation but that has yet to be proved. Perhaps you could prove that this is always a product of two cycles, one with two transpositions, the other with an odd number of transpositions.
If the answer, as is implied by the question, is independent of n, then this is an odd permutation.
Thank you for posting Hallsoflvy, someone explained this problem to me in this way:
"So an inversion is (i,j) with i<j and p(i)>p(j) and the sign is (-1)ⁿ with n the count of inversions. You have that permutation in tableau form, so you can read off what p(i) is for each i.
If i<j with i,j in 1..n, then p(i)>p(j), inversion, and there are C(n,2) of those.
If i<j with i,j in n+1..2n+1, then p(i)<p(j), and it's not an inversion.
If i<j with i in 1..n, and j in n+1..2n+1, then p(i)>p(j), inversion, and there are n² of those.
C(n,2) + n² = n(n-1)/2 + n² = n(3n-1)/2"
But I still don't understand it and neither the explanation mentioned by this person. I've had the help of other people as well but I still don't get it. It's easy to count the inversions in permutations of the form {2,4,5,1,3} etc. but this particular problem just seems so complicated to me (or maybe who knows, probably I have a learning disability of permutations?
