How do I find conversions for a reaction with phosphoric acid?
  • Thread starter Thread starter Rub3y
    Acid Reaction
The discussion revolves around the reactions of a solid ash mix containing various oxides and salts with phosphoric acid, which is a weak acid. The main concern is the incomplete conversion of reactants due to the weak nature of phosphoric acid, leading to uncertainty about the conversion percentages. While it is acknowledged that stoichiometric equations can be written and balanced, the actual conversion yield can only be determined experimentally. Participants suggest that while phosphoric acid does not fully dissociate in water, the dissociated parts may still react with other components in the mixture. There is an emphasis on the need for practical experience and possibly consulting with a knowledgeable chemist for more accurate insights. Overall, the conversation highlights the complexity of predicting chemical reactions in this context and the importance of empirical data.
Rub3y
TL;DR Summary
Salts and oxides react with phosphoric acid. How do I get conversion %?
I have a solid ash mix containing oxides(ZnO, NiO, MgO, Cr2O3, etc.) and salts (Na2SO4, K2SO4, apatite, etc.). I am supposed to write all of the reactions with phosphoric acid (should be between 1 and 2 mol/l) and put it in a simulation for mass and energy balances. But since phosphoric acid is a weak acid, this stuff doesn't 100% convert, right? Or maybe not at all...? I can look for the reactions no problem, but I have no idea how I would search for the conversion %. Can I maybe make some assumptions fe conversion of everything is 50%. Can anyone give me some tips on how I best handle this or which assumptions I can make?
Chemistry news on Phys.org
It's hard to tell. In the end, the conversion (yield) can only be determined experimentally. Stoichiometrically, you simply have to write and balance the equation(s). Phosphoric acid is a weak acid, so you are correct in that it doesn't fully dissociate in water, but this does not mean that the parts that do come from dissociation do not fully react with the other reactants (at least this is a decent assumption).
Excellent idea! Exactly what I needed.
I hope what I said was clear. Again I would probably run it by @Borek or another experienced chemist. My knowledge of inorganic chemistry is honestly... lacking.
Nah, what you wrote is perfectly valid, there is no simple answer here and unless someone works with exactly such mixtures and has some hands on experience it is pretty hard to add something.
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
