How Do I Find the Coefficient of Friction Using Potential Energy?
  • Thread starter Thread starter hanagasumi
    Hi Homework
To find the coefficient of friction using potential energy, start with the equation that relates gravitational potential energy to kinetic energy and frictional force. The formula provided is gh = v^2 + Ucos(Angle) * d * g, where U is the coefficient of friction. Calculate the frictional force (FR) using the equation 1/2 mv^2 + FR * d = mgh. Once you determine FR, relate it to the coefficient of friction by using the formula FR = U * N, where N is the normal force. This approach will help clarify the relationship between potential energy and friction in your homework problem.
hanagasumi
Hi, I really need help with my homework!
I had a home work, it is like:
I have a data table, that has
Initial Position: 1.652m from the sensor
Final Position: 0.977m from the sensor
Initial Velocity: 0.003m/s
Final Position: 1.366m/s
Angle: 27 degrees
g = -9.8m/s^2
U represent the variable for coefficient of friction
The question asks me to find the coefficient of friction, by using the formula according to the potential energy, it's like
gh= v^2+ UcosAngle*d*g
I'm so confused! Please help me@!
Thank you in advance!
Just use
\frac{1}{2}mv^2 + F_R d = mgh
and find the frictional force FR and then see how FR relates to the coefficient of friction.
thank you !
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
