How do I find the normal modes of massless string w/ masses?
To find the normal modes of a massless string with three equally spaced masses, the tension T and length L are crucial for calculating the frequencies of transverse motion. The velocity of the wave is determined by the formula sqrt(T * L / M), and the fundamental frequency is given by ν1 = √(T/(4ML)). The attempt to use coupled oscillators led to incorrect results, prompting a reevaluation of the calculations. The correct frequencies for the smallest three modes are approximately 0.84ν1, 1.55ν1, and 2.04ν1. Detailed calculations are necessary to identify any mistakes in the initial approach.
ChickenTarm
So, a string with length L and a mass of M is given tension T. Find the frequencies of the smallest three modes of transverse motion. Then compare with a massless string with the same tension and length, but there are 3 masses of M/3 equally spaced. So this is problem #1
http://www.physics.purdue.edu/~jones105/phys42200_Spring2013/Assignment_5_Spring2013.pdf
ν * λ = velocity
velocity = sqrt(T * L / M)
νn = nν1 n = 1, 2, 3
ν1 = √(T/(4ML))
I tried using coupled oscillators and the equation for finding the frequencies.
ωq=2ω0|sin(q/2)|
q = nπ/(N+1) where n is the index and N is the number of particles
This does not give me the correct answer.
The correct answer is: .84ν1, 1.55ν1, and 2.04ν1.
Hello. Welcome to PF!
What did you use for ωo?
ω02 = T/((M/3)(L/4))
OK. That should give the correct answer. You'll have to show your detailed calculations in order to find the mistake.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
