How do I find the work and power if I have a mass in Newtons?
To find work when climbing stairs, it's essential to convert weight correctly into Newtons without unnecessary multiplications. The user initially converted their weight of 135 pounds to Newtons using a factor of 4.5, resulting in 607 Newtons. However, multiplying by 9.8 m/s² again was incorrect, as the force is already expressed in Newtons. Work is calculated as force multiplied by distance, so only the force in Newtons and the distance in meters should be used. Clarifying units and avoiding redundant calculations is crucial for accurate results.
MoreZitiPlease
Im trying to find my work when climbing up stairs. If I convert my weight into Newtons, do I still need to multiply it by 9.8? Since i weigh 135, I multiplied that by 4.5 to get my weight in Newtons. I then multiplied that by 9.8, after that I multiplied that by 3.0 m ( the distance of the stairs). I got a really big number
that okay?
Why did you multiply by 4.5? 135 what?
135 pounds
1pound=4.45 Newtons
So then why did you multiply by 9.8 again if you already have your weight in Newtons?
No, it's not ok. You only put units on the height of the stairs. Put units on EVERYTHING. You weight 135? 135 what? I'm guessing lbs. Don't make me guess. So then 135lb*4.5N/lb=607N is already a force unit (Newtons=kg*m/sec^2). I'm guessing when you said 9.8 you mean 9.8m/sec^2. Work is force times distance. Is 607N*9.8m/sec^2 even a force unit? Can you answer your own question? "If I convert my weight into Newtons, do I still need to multiply it by 9.8?". Yes or no?
no, you dont..
okay, thanks
let me change my data
thanks
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
