How do I prove that a sequence is open?
  • Thread starter Thread starter lolalyle
    Sequence
lolalyle
Let B be an open set. Let x \in A. Let sn be a sequence such that lim sn=x. Then there exists an N such that sn \in A for all n>N.
Definition of Open Set: S is open if for every x \in S, there exists an E>0 such that (s-E,s+E) \subset S
Prove that the sequence is open.
Let E>0 be given.
Let x \in A be given.
Let lim sn=x.
Choose N such that ... for all n>N.
The first sentence of your post should be "Let A be an open set" I guess..
.\quad A
(--------x-)
And then you have a sequence of number that converge to x. What is the definition of a sequence converging to a number?
For all E>0, there exists a real number N such that for all n in the natural numbers, n>N implies that abs(sn-s)<E.
So basically you can get as close to x as you want as long as you chose a N big enough.
Do you see that this together with that A is open will give you the required result?
Yes! Thank you. I definitely do not know why I didn't see that in the first place.
If a sequence is not bounded does it have a maximum?
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
